I've tested this numerous times. Whenever I enable any hubitat device (switch or dimmer) via the mcsHubitat plugin, and then run the rediscovery in GH, I get the "something went wrong error". If I disable the voice command for the Hubitat device and then only enable voice command for any other HS device, GH rediscovery works no problem.
Has anyone else run in to this issue?
Wayne
Wayne
