Hi Wim, This is an error message I have in my log .
JowiHue Error Error: (InitialSensors)::Arithmetic operation resulted in an overflow.
Matthieu,
Can you check the version of the plugin you are running? I think you do not have the latest, 4.0.1.1. The error you are seeing is from an earlier version that should be gond. For the HS3 version of the plugin I noticed HST had reverted the latest update, so they might have made the same error with the HS4 version?
Wim-- Wim
I am doubting myself here... I submitted a new beta 4.0.1.2 here. Minor changes, mainly some small bugs and code cleaning. Made sure it is good now.
Wim-- Wim
- 1 like
