I had moved the Philips bulbs from JowiHue to the HS4 Philips PI but I lost an important function, dimming and brightening. With your PI I can set a brightness level or hold the switch to dim or brighten. Perfect. I can't do that with the HS4 PI. I can set brightness levels to a desired number but can't brighten or dim by holding down a switch at least as far as I can figure out.
Thanks again for an awesome PI.
