Description JowiHue for HS4
This topic is closed.
This is a sticky topic.
    JowiHue provides a real-time, interactive interface between your Zigbee devices and HomeSeer. It is compatible with ZigBee devices (ZigBee Home Automation (ZHA) 1.2, ZLL, ZigBee 3.0) through gateways (Philips Hue bridges or deCONZ gateways).
    With JowiHue, you are provided with a set of very configurable tools to create, maintain and trigger devices, presets, scenes and animations for any light connected to either a Philips Hue Bridge or a RaspBee (II) or ConBee (II) with the deCONZ gateway installed.
    You can control your lights from anywhere, without the real need to open your lights to the Internet Of Things or in any way to the rest of the world, as long you have access to your Homeseer website or have HSTouch connected.
    The plugin can coexist with any other apps controlling your Philips Hue or deCONZ gateway, the plugin will not get in the way, but can take care of your daily routines safely from inside your house without a need of a phone or tablet.
    Are you depending on that nifty trick from IFTTT to get a warning that you have mail from your loved ones by blinking your Hue lights? Why not use Homeseers mail functions to trigger your lights? No one else needs to know you've got mail!
    Anticipating for the blue lights because it rains outside? If you have a weather station, connect it to Homeseer and you can set your own triggers to set the lights accordingly. Then it is no longer based on predictions, it is real time!
    You will find lots more while playing with this plugin. Have fun!
    Features
    • Runs on Windows and Linux
    • Multiple bridges support in any combination of Philips or Raspbee/Conbee.
    • Extended support for Philips Hue HDMI Sync boxes
    • No dependency on cloud services.
    • Presets with advanced editor and snapshot functionality. Presets are light recipes that can be applied to any colour bulb by event or scene.
    • Scene support with advanced editor, local scenes can combine any lights from different bridges. (Remote) Scenes present on the gateways can also be used in the plugin.
    • Animation with advanced editor. Combine scenes to achieve special effects, like creating an alert effect, or a combination of scenes to create a romantic mood during dinner with changing color of lights. Animations can last a specific amount of time or can be stretched until a set time (eg sunrise or sunset).
    • Supporting many types and brands of lights and sensors
    • Full control of lights and groups through device utility page and events.
    • Optionally recover last known settings after switching (power off) off a bulb and switching it back on..
    • Keep track of lifetime information per light and create a lifetime report on request.
    • When using a ConBee/Raspbee, you can have a alarmsystem based on the lights and sensors in your house
    • Event triggering based on status of groups of lights or individual lights.
    • Event actions available for setting lights, groups, with presets, scenes or animations
    • Scripting engine for direct control of the ZigBee lights
    • HomeSeer HS4 or HSPRO 4
    • JowiHue Plug-in For HS4
    • The plugin is supported on Windows and Linux
    • (any number of) Philips Hue Bridge(s) or RaspBee(s) or ConBee(s) with deCONZ running on them.
    • For using the Hue HDMI sync box control, a Hue HDMI Sync box...
    Last edited by w.vuyk; September 30, 2021, 04:05 PM. Reason: Adding alarm systems for deCONZ
    -- Wim
