JowiHue Plugin for HS4
This topic is closed.
This is a sticky topic.
    #31
    Release 4.0.6.1 Februari 2022
    • Corrected the update of RGB values on light devices
    • Adjusted the message shown when a battery is low (or dead)
    • Replaced UPNP search for Philips bridges by mDNS searches as UPNP will be disabled for Philips Hue bridge in Q2 of 2022
    • Pressure conversion enabled HPA-inHG-mmHG
    • Changed statuses for Lights (only after refresh of devices)
    • Changed unreachable settings for lights
    • Added support for Air Quality (TVOC) sensors
    • Enabled suppressing dim effect for RGB changes
    • Solved an issue with editing groups in the bridge maintenance page
    Notes:
    You will find the option to change the display value of Pressure feature in the settins page of the plugin
    Details on the changed statuses of lights: The dim values of a light are change to 1-99% The 100% value of a light is replaced by the status "On". This is not converted automatically, but can be applied per light (Reset Graphic values for all features belonging to devices) on the JowiHue tab of a feature of by selecting the same option in the settings page (Miscellaneous settings)
    -- Wim
      #32
      Release 4.0.6.3 Februari 2022
      • Solved an issue with a XML file
      • Solved an issue with Air Quality devices
      -- Wim
        #33
        Release 4.0.6.7 April 2022
        * Activating APIV2 for Philips Hue (Events Only)
        * Solving issue with the latest PluginSDK
        * Solving issue with creation of CT devices
        * Added support for Sirenes
        * Enabling showing floortemperature on thermostats
        * Basic support for Lutron Aurora (ZLLRelativeRotary)
        * Solving a major issue where a Philips Hue bridge can be confused with deCONZ
        * Solving errors during creation of sensors
        Remarks:
        In this release the first part of the new APIV2 for Philips Hue bridges is used. So far limited to the most valuable feature, the events of the API. This means the frequency polling can be relaxed on the Philips Hue bridge. The bridge is still polled now and then, to sync eventual misses. The events send by the bridge should be caught for most types. This is also still in development, so please let me know if you see lines in the log on missed events so I can try the catch these in a next version?
        Events are send only once per second, it are NOT webhooks that have an immediate response. So if you want to catch the triple clicks or double clicks on a switch, deCONZ is still the better. But responses on updates are a lot snappier with this update!
        -- Wim
          #34
          Release 4.0.6.8 April 2022
          • An error occured when using a while light on a Philips Hue bridge.
          • Unneeded logging moved to debug level
          Solving an issue from the latest release
          -- Wim
            #35
            Release 4.0.6.9 May 2022
            • Added humidity offset in the device properties
            • Removed certain logging of APIV2 lines
            • Solved an issue where the plugin would restart on battery updates for the Philips Hue bridges
            • Enabled using effects Fire and Candles on the Hue Philips bridge
            Remark on the new effects: The effects will be added to the Extra device for lights that are effects enabled on the Philips Hue bridge. Not all lights are effects-enabled on the Philips Hue bridge. Especially older lights are not enabled as those lights do not have enough memory for using the effects. So you will not see these extra buttons for every device.
            -- Wim
              #36
              Release 4.0.7.0 May 2022
              • Enabled the use of dynamic scenes on the Hue bridge
              • Enabled the use of searchable lists in the JowiHue actions of events
              How to use the Dynamic events on the Philips Hue bridge
              In an event, use a JowiHue action "Set Event"
              Select an event that is defined dynamic on the bridge ( bridge events start with bridge: <scenename> )
              If the scene can be used with the dynamic setting, enable the dynamic switch and save the action:
              Click image for larger version  Name:	2022-05-13 18_15_51-Event.png Views:	0 Size:	37.4 KB ID:	1544889
              Have fun!
              -- Wim
                #37
                Release 4.0.7.2 May 2022
                • Solved an issue when using both a Philips Hue bridge and a deCONZ gateway
                • Solved an issue when updating temperature values on the new Philips API
                • JowiHue action for scenes changed to show the group a bridge scene is using.
                • Solved an issue using bridgescenes
                • Solved a major issue where maintenance on gateways was no longer performed
                • added support for aqara motion sensor FP1
                • Correcting the update of the dim setting of lights
                • Corrected an issue when using a JowiHue action on scenes when not using the dynamic setting.
                Regarding the major issue on maintenance on the gateways. This was causing slow or no creation of new added devices. For new installations it would cause a load of errors when a bridge was joined. These have been solved now. If you tried to add a new bridge or did a fresh install of the plugin with new gatews/bridges, it could be best to remove the device created by the plugin and start the plugin after that. This should result in a clean install of the devices again now.
                Sorry for the hassle created here. One advantage because of this, the plugin starts a lot faster now
                -- Wim
                  #38
                  Release 4.0.7.3 June 2022
                  • Adjust refresh rates for all gateways when using the eventstream or webhook
                  • Added a correction for lights on Hue bridges
                  • Added new device configuration options (device properties/JowiHue tab)
                  • Changed standard type of creating new groups to Zone
                  • Fine tuning Aqara FP1 motion sensors
                  • Changed handling and logging of devices using Hue APIV2 combined with APIV1
                  • Solved an issue with White only devices on Philips Hue bridges making them uncontrollable
                  • Solved an issue with Linux handling with the new API
                  • Corrected using wait time in events
                  -- Wim
                    #39
                    Release 4.0.7.4 June 2022
                    Important!
                    This release solves major issues with the last version with Philips Hue bridge. If you are running 4.0.7.3 and use Philips Hue bridges, please upgrade!
                    An issue with the Philips Hue ApiV2 is also discovered, which has to be solved by the devs of the Philips Hue APIV2
                    • Solved an issue when renaming a device with a name > 32 characters, removing character from the left instead of right
                    • Solved the doubling of feature function name (like Motion) in the feature names
                    • Solved showing double lights in groups
                    • solved the creation of extra CT devices for lights
                    • Solved the logging of the dual devices: Both devices are pointing to the same light. Follow up on the message, remove the device that is mentioned!
                    -- Wim
                      #40
                      Release 4.0.7.5 July 2022
                      This release is mainly for group control on the Philips Hue bridge, solving issues, but also streamlining the update send by the APIV2 of the Hue bridges.
                      • Solved an issue where Room groups would only show one light in Bridge Maintenance
                      • Updating a group's lights throws an error in the log
                      • Groups would not always create the correct features on the group.
                      • Groups were no longer automatically created as new devices
                      • Lightgroups are no longer supported on the Philips Hue bridge (Rooms and Zones only)
                      • removed some test logging from the standard logging
                      -- Wim
                        #41
                        Release 4.0.7.6 August 2022
                        • Double check the existence of all light features
                        • Improve error checking in APIV2
                        • Correction of version number
                        • Various bugs solved
                        -- Wim
                          #42
                          Release 4.0.7.7 September 2022
                          • Solved a situation where a race could start with renaming devices
                          • Enabled the dump button on the bridge maintenance page
                          • Added extra tracing for power reporting for plugs on the Philips bridges
                          • Improved group handling
                          • Solved an issue where a JowiHue action could stop working when the device was removed and re-added.
                          -- Wim
                            #43
                            Release 4.0.7.9 September 2022
                            • Solved an error while setting group values.
                            • Solved an issue with calculating the RGB values
                            • Excluded Rotary devices, needs more work
                            • Corrected the output from the dump button on bridge maintenance. It is now working on Linux as well
                            • Corrected the version reported on plugin maintenance page
                            -- Wim
                              #44
                              Release 4.0.7.10 September 2022
                              • solved an issue with updating devices based on the Eventstream from Philips Hue bridges
                              • Restructured the way devices are created
                              • Solved an issue with hidden sensorgroups on deCONZ
                              • Bridge Maintenance page stopped refreshing when a button was pressed. This is solved
                              -- Wim
                                #45
                                Release 4.0.8.0 October 2022
                                * resolved an issue with reconnecting bridges
                                * resolved an issue with the refresh of devices
                                * resolved an issue with adding extra features to sensors (battery and volt measurement (etc) features)
                                * Resolved updating groups based on lights change on a Philips Bridge
                                * Device type string information is correct added to the feature‚Äč
                                -- Wim
