HS4 JowiHue 4.0.2.0 Plug-in Bridge Maintenance page is empty (Linux)
    HS4 JowiHue 4.0.2.0 Plug-in Bridge Maintenance page is empty (Linux). Screenshot is attached.
    Setup:
    Date/time=7/11/2020 12:30:40 PM PDT
    Version=HS4 Pro Edition 4.1.1.0 (Linux)
    License=Registered
    Uptime=0 Days 22 Hours 52 Minutes 55 Seconds
    Lan IP=10.0.10.150 (HomeSeer-MacMini.local)
    Device Count=690
    Event Count=105
    Plugins Enabled=Z-Wave:,Rachio:,Chromecast:,RFXCOM:,JowiHue:
    Modules/Threads=220 Modules, 10 Threads
    Available Threads=1199
    HomeSeer Memory Used=297 Mbytes
    Plugins Installed=Chromecast 4.0.12.0,JowiHue 4.0.2.0,Rachio 4.0.0.0,RFXCOM 30.0.0.41,weatherXML 3.0.1.19,Z-Wave 3.0.2.0
    Could you send me a trace of what might be happening? Are events and/or device control working fine?
    • set verbose logging and log to file in the settings of the plugin
    • Stop and restart the plugin
    • Let it finish initializing and then open the bridge maintenance page.
    • Disable the verbose logging and log to file options
    • Send me the file /Logs/JowiHue.log ? Send it to jowihue at ziggo dot nl
    Wim
    -- Wim
      Hi Wim,
      The events and device control are working fine.
      The log supposed to be in /usr/local/HomeSeer/Logs/JowiHue.log but the plug-in didn't create it.
      I copy/paste output of /usr/local/HomeSeer/Logs/daemon_run.log instead and just sent it to you. I hope it is OK.
      Thank you,
      Denis
