Rename of Devices
    Rename of Devices
    I installed 2 range extenders, 2 temps sensors and 1 water sensor in Deconz. It's my understanding that Deconz will at some point rename the devices. Once the devices have renamed I can scan for devices from the plugin. I restarted Deconz and when it started back up I lost one of the sensors. Being that they have not renamed I am not sure which one. How long should it take before the devices rename in Deconz? It's been about 11 hours and only one range extender has renamed. Am I doing things correctly?
    Jim
    Jim,
    I do not know really. Range extenders have no active function in Phoscon or JowiHue and I honestly do not know how deCONZ handles it. If it should be renamed in the interface, the only way I could think of to enforce deCONZ to proceed on recognision is to start a new scan for devices and an immediat power pull (count till 10) and resinsert to power - or perform the reset during this search to proceed in discovery?
    Wim
    -- Wim
      I uninstalled Deconz and started over. I have only did one temp sensor but it's been about an hour and it has not renamed. Don't I need to wait till the device gets renamed before the plugin will see the device?
      Jim
        Jim,
        During scanning for devices (2 minutes) keep this temp sensor busy. Is it Xiaomi or Aqara? If it is, press the small button once per one second or so, ot start a rescan of devices and reset the device by holding the small button for 4 to 5 seconds (blue light blinks). In deconz you do NOT need to remove the device and you should see a dot blinking on the new device. Here it takes max 10 seconds to recognize the device. If this does not work, try in Phoscon as well?
        Wim
        -- Wim
          It's a Aqara temp sensor. I tried 4 times, Did not rename. I tried the Phoscon app but my password not working. I pulled the Conbee II to power cycle and password reset failed so I no longer can login to Phoscon.
            I just uninstalled everything. Reinstalled, reset ConBee II, put in new password for Phoscon. Still didn't work and again password not working. What's the default password for Phoscon?
              Jim,
              Try going through the dresden electronics gateway site: http://phoscon.de/app does it give you the opportunity to set or reset the password?
              Wim
              -- Wim
                I unplugged the ConBee II several times and finally got it to reset the password but every time I need to log back in it says wrong password. I used Phoscon to get both temp and both water sensors in. Now the Webapp says invalid password so I can't register the bridge. I never changed the password.
                  I unplugged the Conbee again and was able to reset the password. In the plugin, there is two Phoscon-GW. Is this correct?
                    I did get the 2 water and 2 temp sensors to add and rename through Phoscon. I do have a button I couldn't get added either way. I added the 2 Routers in deCONZ.
                      Jim,
                      The device you are looking at is 1 Devices and 1 Feature. Welcome to HS4
                      -- Wim
                        Jim,
                        Ok thanks. I just wanted to make sure I didn’t do something wrong.
                        Jim
