JowiHue strange errors at startup
    Hi,
    Since I upgrade 5 days ago from HS3 to HS4, and upgrade JowiHue PI to 4.0.2.3, when starting HS4, at start-up log, I get some strange errors concerning my ZigBee device like dimmer micro switch :
    16-08-20 08:19:37 HomeSeer~!~Info~!~Plugin JowiHue with instance JowiHue has connected. IP:127.0.0.1:50193
    16-08-20 08:19:37 HomeSeer~!~Starting Plug-In~!~Initializing plugin JowiHue ...
    16-08-20 08:19:38 JowiHue~!~Info~!~Logfile is set to C:\Program Files\HomeSeer HS4/Logs/JowiHue.log
    16-08-20 08:19:38 JowiHue~!~Info~!~Starting plugin JowiHue 4.0.2.3 on Windows
    16-08-20 08:19:38 JowiHue~!~Info~!~settings loaded
    16-08-20 08:19:38 HomeSeer~!~Starting Plug-In~!~Plugin JowiHue started successfully in 451 milliseconds
    16-08-20 08:19:38 HomeSeer~!~Starting Plug-In~!~JowiHue loaded in 1032 milliseconds
    16-08-20 08:19:38 HomeSeer~!~Plug-In~!~Finished initializing plug-in JowiHue
    16-08-20 08:19:40 JowiHue~!~Info~!~* Connected to bridge Philips hue at 192.168.1.116:80
    16-08-20 08:19:40 JowiHue~!~Error~!~Error: (InitDevices):Error while scanning device Hue dimmer mur CDM La clé donnée était absente du dictionnaire.
    16-08-20 08:19:40 JowiHue~!~Error~!~Error: (InitDevices):La clé donnée était absente du dictionnaire.
    16-08-20 08:19:40 JowiHue~!~Error~!~Error: (InitDevices):Gathering information from device Hue dimmer mur CDM ref:3375 of type unknown
    16-08-20 08:19:40 JowiHue~!~Error~!~Error: (InitDevices):Error while scanning device Hue dimmer Cuisine La clé donnée était absente du dictionnaire.
    16-08-20 08:19:40 JowiHue~!~Error~!~Error: (InitDevices):Gathering information from device Hue dimmer Cuisine ref:3376 of type unknown
    16-08-20 08:19:40 JowiHue~!~Error~!~Error: (InitDevices):Error while scanning device Hue dimmer CDM chevet La clé donnée était absente du dictionnaire.
    16-08-20 08:19:40 JowiHue~!~Error~!~Error: (InitDevices):Gathering information from device Hue dimmer CDM chevet ref:3377 of type unknown
    6-08-20 08:19:43 JowiHue~!~Info~!~Started Philips bridge Philips hue
    16-08-20 08:19:43 JowiHue~!~Info~!~HTTPS access enabled on bridge Philips hue
    16-08-20 08:19:47 JowiHue~!~Info~!~=========================================== ===================================================
    16-08-20 08:19:47 JowiHue~!~Info~!~33 lights and/or plugs connected to bridge 'Philips hue'
    16-08-20 08:19:47 JowiHue~!~Info~!~16 Groups available on bridge 'Philips hue'
    16-08-20 08:19:47 JowiHue~!~Info~!~Bridge Philips hue is at version 1940042020 of type BSB002
    16-08-20 08:19:47 JowiHue~!~Info~!~3 Remote switch found on bridge 'Philips hue'
    16-08-20 08:19:47 JowiHue~!~Info~!~3 Motion sensor(s) found on bridge 'Philips hue' with 3 supporting HS device(s)
    16-08-20 08:19:47 JowiHue~!~Info~!~3 Temperature sensor(s) found on bridge 'Philips hue' with 3 supporting HS device(s)
    16-08-20 08:19:47 JowiHue~!~Info~!~3 Lightlevel sensor(s) found on bridge 'Philips hue' with 3 supporting HS device(s)
    16-08-20 08:19:47 JowiHue~!~Info~!~1 Daylight sensor found on bridge 'Philips hue'
    16-08-20 08:19:47 JowiHue~!~Info~!~10 Generic status sensor found on bridge 'Philips hue'
    16-08-20 08:19:47 JowiHue~!~Info~!~-------------------------------------Bridge info ---------------------------------------------
    16-08-20 08:19:47 JowiHue~!~Info~!~23 Presets available for use in the JowiHue plugin
    16-08-20 08:19:47 JowiHue~!~Info~!~19 Local scenes available for use in the JowiHue plugin
    16-08-20 08:19:47 JowiHue~!~Info~!~5 Animations available for use in this plugin
    16-08-20 08:19:47 JowiHue~!~Info~!~-------------------------------------Plugin info ---------------------------------------------
    16-08-20 08:19:48 JowiHue~!~Info~!~Adding feature for Hue dimmer Cuisine (ZLLSwitch)
    16-08-20 08:19:49 JowiHue~!~Info~!~Adding feature for Hue dimmer mur CDM (ZLLSwitch)
    16-08-20 08:19:49 JowiHue~!~Info~!~Adding feature for Hue dimmer CDM chevet (ZLLSwitch)
    And on HS4 Errors/Warning window
    16-08-20 08:19:11 HomeSeer~!~Error~!~Error while deserializing object from database : Unterminated string. Expected delimiter: ". Path 'K3518.plugExtraData', line 1, position 5823032.
    16-08-20 08:19:11 HomeSeer~!~Error~!~Error while reading devices.json : La référence d'objet n'est pas définie à une instance d'un objet.
    16-08-20 08:19:13 HomeSeer~!~Error~!~Unable to load counters from normal or backup file!
    16-08-20 08:19:40 JowiHue~!~Error~!~Error: (InitDevices):Gathering information from device Hue dimmer CDM chevet ref:3377 of type unknownStartup Complete, 12 errors detected, check the log for more information.
    And sometime, when starting, all sensor info are not in the PI.
    What is that ?
    Tanks.
    JYA
    I worry about seeing these lines:
    This might point to a corrupted devices.json file. Since when do you see this error? Is it possible for you to go back to a backup of HS4 that does not show this error? You can filter the log on this issue by setting the start date back to the time you did the conversion and filter on the above string.... If you see this issue from the first start, you might have to even restore HS3 and do a clean start.
    The JowiHue errors might be a result of th corrupted devices, cannot tell you for sure here as it is yet unclear what devices are now damaged by this error.
    Maybe contact HomeSeer support for this one too... Make clear to them that the first issue shown is the above two errors... the rest could probably be caused by this.
    Wim
    -- Wim
      Tank you for your quick reply.
      I did a clean installation of HS4 this morning, and a restore from backup.
      The HomeSeer errors are gone, but remain the JowiHue errors.
      JYA
        Ok, that is good news, the json error is gone. The Hue Dimmer is the issue here. Is it possible for you to remove the devices belonging to the dimmer? When you do this, just make sure to stop the JowiHue plugin and then remove the Hue Dimmer. When the plugin is restarted, the Dimmer devices are recreated and all should be good from there. Make sure to test a restart too after the devices are recreated?
        Wim
        -- Wim
          OK, I will do that and post you.
          Tanks again
            Did it, exactly as you asked.
            Restart HS4, and even shut down my PC, restarted it, restarted HS4 and..........
            😊 no more JowiHue PI error message!!!
            You are the best (and I am glad to have paid for your HS4 PI).
            Merci beaucoup.
            Thank you very much
            Hartelijk dank
            JYA
              Great to hear! Good to see the Dutch response too!
              -- Wim
