My system is running HS4, and was until recently running the legacy JowiHue plugin.
I had added an Aqara Wireless Mini Switch. But after a couple of days, I lost contact with the switch in HS4. I can see in deCONZ that it responds to button presses, but the event is not fired.
Since then I tried removing the switch, first in Phoscon and then in HS4, and then re-added the switch in Phoscon (which worked fine) and restarted the (legacy) JowiHue plugin. But I did not get the switch back in HS4 again.
After this, I upgraded the JowiHue to the HS4 plugin. But I still don't get the switch added in HS4 again.
I see in the log that I get the following error message when restarting the JowiHue plugin:
Can this be related to the switch not being added? What do I do about it?
Here's the entire log from starting the plugin:
