Change status on trådfri on/off switch from motion detected
    Hi,
    Does anyone know if it is possible to set the status of an trådfri on/off switch from an event?
    My scenario is like this:
    I have some lights turned on/off from a trådfri switch (works fine)
    Then I have added a motion sensor to turn off lights when there has been no motion for 15 minutes (works fine)
    The problem is - when motion sensor has turned off lights - the status on the switch is wrong and you have to press off before being able to turn lights on again.
    Anyone have good solution to this issue - I cant be the only one with this issue :-)
    /Claus
