Can turn on/off/dim but color doesnt work
    Fresh Install of HS4Pro with the HS4 version of the plugin. I paired the bridge, i can turn it on/off and dim it. However, I the other child controls do not seem to be working as i can not change the color, etc...
    JowiHue
    Error
    Error: (GetJuiDeviceConfigViews):Error Object reference not set to an instance of an object.
    JowiHue
    Error
    Error: (GetJuiDeviceConfigViews):Error System.NullReferenceException(0x80004003): Object reference not set to an instance of an object. at HSPI_JowiHue.DeviceConfigPage.ConfigPageLight(SortedDictiona ry`2& viewDictionary, HsFeature HsFeature, String pageid, List`1& jsonDictionary) at HSPI_JowiHue.DeviceConfigPage.GetJuiDeviceConfigViews(String Pageid, Int32 DeviceRef)
    I have a test Bridge with a single light that I am playing with (I dont want to break anything used int eh house).
    Here is what I found. While I am not able to change the color of the light. I am able to change the color on an individual bulb! not sure if this is a bug or not.
      I did resolve an issue with group devices on the new version of the plugin. I did send the update to HST. I hope they will publish it today, otherwise it will be on Monday. I think this version will solve the issue with the group device you are seeing.
      Your first log copies though are coming from a different issue I think as they point to the config page of the device properties. Can you remember what you did when these lines we logged? Maybe test the same actions on the new version?
      Wim
      -- Wim
