Jowihue suddenly changed deCONZ address and then it is not to be reached.
    I shut down HomeSeer properly on the Pi. And deCONZ on another Pi.
    Moved them about 1m from where they were. But they are on fixed IP.
    And Jowihue first starts OK, then shuts down because it cannot reach some IP that I never had in my house.
    So I found that there is a new JowiHue. Upgraded it and the problem persist.
    And I can confirm that those TR_xxxxx devices have low battery. in fact I checked and they are in a box here with NO battery!
    I removed the batteries as they are not in use and I dont want any leaking batteries in devices. Go figure!!
    That was done earlier today, and the batteries were from pretty low to empty.
    sep-10 00.00.23 JowiHue Warning: + Bridge 'DeConz' is disconnected - IP 169.254.207.177
    sep-09 23.59.54 JowiHue Warning: Battery of TR_93D2F9 is reporting low (-25%), consider replacing battery.
    sep-09 23.59.53 JowiHue Warning: Battery of TR_9E8DBC is reporting low (-58%), consider replacing battery.
    sep-09 23.59.52 JowiHue Warning: Battery of TR_BED4FC is reporting low (-58%), consider replacing battery.
    sep-09 23.59.52 JowiHue Warning: Battery of TR_9FEDF9 is reporting low (-68%), consider replacing battery.
    sep-09 23.59.48 JowiHue ============================================================ ==================================
    sep-09 23.59.48 JowiHue 2 Animations available for use in this plugin
    sep-09 23.59.48 JowiHue 7 Local scenes available for use in the JowiHue plugin
    sep-09 23.59.48 JowiHue 22 Presets available for use in the JowiHue plugin
    sep-09 23.59.48 JowiHue -------------------------------------Plugin info ---------------------------------------------
    sep-09 23.59.48 JowiHue 2 Vibration sensor(s) found on bridge 'DeConz' with 2 supporting HS device(s)
    sep-09 23.59.48 JowiHue 3 Pressure sensor(s) found on bridge 'DeConz' with 3 supporting HS device(s)
    sep-09 23.59.48 JowiHue 3 Humidity sensor(s) found on bridge 'DeConz' with 3 supporting HS device(s)
    sep-09 23.59.48 JowiHue 8 Open/Close sensor(s) found on bridge 'DeConz' with 8 supporting HS device(s)
    sep-09 23.59.48 JowiHue 1 Daylight sensor found on bridge 'DeConz'
    sep-09 23.59.48 JowiHue 7 Lightlevel sensor(s) found on bridge 'DeConz' with 7 supporting HS device(s)
    sep-09 23.59.48 JowiHue 3 Temperature sensor(s) found on bridge 'DeConz' with 3 supporting HS device(s)
    sep-09 23.59.48 JowiHue 8 Motion sensor(s) found on bridge 'DeConz' with 8 supporting HS device(s)
    sep-09 23.59.48 JowiHue 12 Remote switch(s) found on bridge 'DeConz' with 12 supporting HS device(s)
    sep-09 23.59.48 JowiHue Bridge DeConz is at version 2.5.79 of type deCONZ on a RaspBee
    sep-09 23.59.48 JowiHue 18 Groups available on bridge 'DeConz'
    sep-09 23.59.48 JowiHue 35 lights and/or plugs connected to bridge 'DeConz'
    sep-09 23.59.48 JowiHue -------------------------------------Bridge info ---------------------------------------------
    sep-09 23.59.45 Z-Wave Warning Z-Wave Multilevel Sensor device 1.Etg. Gang Panelovn gang is missing Sensor Type information - cannot update sensor status.
    sep-09 23.59.12 JowiHue * Connected to bridge DeConz at 192.168.1.32:80
    sep-09 23.58.41 Starting Plug-In Plugin JowiHue started successfully in 2519 milliseconds
    sep-09 23.58.41 JowiHue InitIO:Plugin basic initialisation done
    sep-09 23.58.40 JowiHue Starting plugin JowiHue 2.1.1.3 on Linux
    sep-09 23.58.39 Starting Plug-In Initializing plugin JowiHue ...
    I just answered your message in the HS3 forum? LOL
    -- Wim
