Scenes not Working
    Scenes not Working
    Hi,
    I just upgraded from the HS3 version to the HS4 version and all seemed to go well. The problem is that my scenes do not work any more when running an event. I can control lights individually and I can see the scenes in the drop down when creating an event and selecting set scene, but they do not actually work. I looked at the log for the conversion and this is what is said:
    Warning: Battery of Master Bedroom switch 2 is reporting low (2%), consider replacing battery.
    9/19/2020 12:48:19 PM
    JowiHue
    Warning
    Warning: Battery of Upstairs Landing switch is reporting low (3%), consider replacing battery.
    9/19/2020 12:48:17 PM
    JowiHue
    Info
    JowiHue
    Info
    -------------------------------------Plugin info ---------------------------------------------
    JowiHue
    Info
    0 Animations available for use in this plugin
    JowiHue
    Info
    0 Local scenes available for use in the JowiHue plugin
    JowiHue
    Info
    22 Presets available for use in the JowiHue plugin
    JowiHue
    Info
    JowiHue
    Info
    -------------------------------------Bridge info ---------------------------------------------
    JowiHue
    Info
    5 Generic status sensor found on bridge 'Outdoor Hue'
    JowiHue
    Info
    3 Generic flag sensor found on bridge 'Outdoor Hue'
    JowiHue
    Info
    1 Daylight sensor found on bridge 'Outdoor Hue'
    JowiHue
    Info
    Bridge Outdoor Hue is at version 1940094000 of type BSB002
    JowiHue
    Info
    6 Groups available on bridge 'Outdoor Hue'
    JowiHue
    Info
    36 lights and/or plugs connected to bridge 'Outdoor Hue'
    JowiHue
    Info
    JowiHue
    Info
    JowiHue
    Info
    17 Generic status sensor found on bridge 'Indoor Hue'
    JowiHue
    Info
    1 Daylight sensor found on bridge 'Indoor Hue'
    JowiHue
    Info
    8 Lightlevel sensor(s) found on bridge 'Indoor Hue' with 8 supporting HS device(s)
    JowiHue
    Info
    8 Temperature sensor(s) found on bridge 'Indoor Hue' with 8 supporting HS device(s)
    JowiHue
    Info
    8 Motion sensor(s) found on bridge 'Indoor Hue' with 8 supporting HS device(s)
    JowiHue
    Info
    6 Remote switch(s) found on bridge 'Indoor Hue' with 6 supporting HS device(s)
    JowiHue
    Info
    Bridge Indoor Hue is at version 1940094000 of type BSB002
    JowiHue
    Info
    19 Groups available on bridge 'Indoor Hue'
    JowiHue
    Info
    35 lights and/or plugs connected to bridge 'Indoor Hue'
    JowiHue
    Info
    JowiHue
    Info
    Devices converted to HS4
    I see that is says 0 local scenes available even though there are. What am I missing?
    Thanks for the help.
    Troy
    Do you have local (jowiHue only) scenes, or are you using the scenes on the bridge? I might have missed double checking on the bridgescenes in events in the conversion to HS4..... Will have to look into this.
    -- Wim
      I am using the scenes on the bridge. Is there any way to get them back into HS4?
        You will have them back, in the next version of this plugin I will make sure they are working again.
        Wim
        -- Wim
          Same problem here, just created some scenes in Phoscon on the ConBee2, they don't show up in JowiHue.
          Also, does switch actions associated with a Hue light (on a ConBee2) show up in JowiHue?
            Scenes on deCONZ have not been working in the plugin, will see if I can add them. Switch actions (rules) are not used by the plugin, this is really a Phoscon internal function.
            Wim
            -- Wim
              Got it, thanks Wim.
              If the scene import could happen that would be great, I personally like creating scenes on Phoscon because of the slider control interface.
                I will check on that. But you do know yo can change the brightness of a JowiHue scene as well in an event (JowiHue actions)?
                Wim
                -- Wim
                  Wim
                  Understood, but I'm talking about the initial scene creation, coming up with the right look. I haven't tried creating scenes in JowiHue yet, so maybe I'm missing something.
                    Yup, you are missing something you can set the basic values for the right look using any combination of lights, no matter on which bridge (if you have more then one) the light is connected to. One disadvantage on this is ofcourse that the scene you create is local to JowiHue, you cannot use it from other apps.
                    And if you like a bridge scene, you can activate it through the app (Phoscon) and take a snapshot with JowiHue, to copy all known settings in a new local scene.
                    Just luring you into testing it
                    Wim
                    -- Wim
                      Hey Wim, absolutely. This old dog always wants to learn new tricks and better efficiencies. Was born an engineer, will die one. I'm sure I'll be complaining at my own funeral that "this all could have been done better", LOL.
                        Might be a lot of work, but maybe you can automate that funeral.. LOL Now that is a challenge!
                        -- Wim
