No Bridges in Maintenance after 4.1.7
    #16
    gaf@bluerivernet.com and gjelsvik
    This is definitely an issue with the PluginSDK... if possible, can you revert back to 4.1.6.0 through a backup?
    ​​​​​​​Wim
    -- Wim
      #17
      Tested the upgrade here to 4.1.7.0 and for me it worked fine so far, no error. the more interesting is it to find the device that is causing the error in PluginSDK. Some special device?
      Wim
      -- Wim
        #18
        We have tested a solution for this. It is some issue with the pluginSDK, we have not been able to really put the finger on the issue that pluginSDK is having other then that it is confusing features. But if you delete the device with the reference 1398 the problem is solved. The plugin will recreate the device and run normally after that.
        Wim
        -- Wim
