HUE Bringe not visible in HS4 Pi
    Hi, I have bought the JOWIHUE plugin for HS4. I am trying to install it on my Raspberry Pi 3. After installing I try to connect to my HUE Bridge newerst version, but no brindge is visible. The HUE standard Plugin is installed without problems. What can I do to have JOWIHUE installed? Regards, Jacob
    Jacob,
    The network the plugin is running on has to have UPNP enabled (a router setting) and as backup it needs access to the internet for checking the philips meethue site for the bridges address. Once a bridge is found, you will see a line in the HS log. You then can go to "add new bridges" in the JowiHue plugin menu and register the bridge.
    Let me know if this works for you?
    Wim
    -- Wim
      Hi Wim, Thanks for your quick answer. UPNP is enabled but I do not see where i have to enter it as a backup. Its a sagecom coax router with 1 G WAN Access. I have three ASUS AX AP connected that takes care of my wifi. Does this has a influence. Regards, Jacob
        The backup is just allowing access to the internet for the device the plugin is running on. Normally this is the case, so no problems there I expect.
        Did you try to open the page menu for "add new bridge"?
        -- Wim
          Hi Wim,
          Yes. But nothing is happening. I can get to step 2 - Where the search for my bringe is supposed to show up, but nothing shows up. And I have remebered to push the button on the Hue bringe. You can see it below. Regards Jacob
            Which version of the plugin are you running? What was step 1 holding? Step 1 should have given you a list of bridges found and/or an opportunity to give the IP address of the bridge? Check the image from my machine.
            You should not be able to get to step 2 if no bridges are found....
            Click image for larger version  Name:	2020-10-07 09_06_47-Add Philips Hue Bridge or deCONZ gateway.png Views:	0 Size:	35.7 KB ID:	1424587
            -- Wim
              Hi Wim, No I do not get that dialog. Its version
              I just re-downloaded it again.
              When then when i choose to add new brindge the next screen is this:
              When I enter Next it jumps to the next step
              Do I have to reset my HUI Bridge?
              Thats it. Regards Jacob
                I have the standard HUE Bridge plugin enabled. Does this have an effect?
                Regards, Jacob
                  Could you check the hs4 log for JowiHue messages after restarting the plugin? Is there a message regarding new bridges or errors?
                  -- Wim
                    Hi Wim, Yes a lot. I have attached the log. Please look into it.
                    I have copied all JOWIHUE entrys below
                    10/6/2020 11:41:36 AM JowiHue Info settings loaded
                    10/6/2020 11:41:36 AM JowiHue Info Starting plugin JowiHue 4.0.2.5 on Linux
                    10/6/2020 11:41:36 AM JowiHue Info Logfile is set to /usr/local/HomeSeer/Logs/JowiHue.log
                    10/6/2020 11:41:37 AM JowiHue Info No bridges found
                    10/6/2020 11:41:48 AM JowiHue Info Found new bridge Hue Bio at 192.168.0.10:80
                    10/6/2020 11:42:00 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:42:00 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:42:47 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:42:47 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:47:48 AM JowiHue Info JowiHue Plugin closing now. Thanks for using it :-)
                    10/6/2020 11:47:57 AM JowiHue Info No bridges found
                    10/6/2020 11:47:57 AM JowiHue Info settings loaded
                    10/6/2020 11:47:57 AM JowiHue Info Starting plugin JowiHue 4.0.2.5 on Linux
                    10/6/2020 11:47:57 AM JowiHue Info Logfile is set to /usr/local/HomeSeer/Logs/JowiHue.log
                    10/6/2020 11:48:08 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:48:09 AM JowiHue Info Found new bridge Hue Bio at 192.168.0.10:80
                    10/6/2020 11:48:09 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:48:09 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:48:16 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:48:16 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:48:49 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:48:49 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:48:57 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:48:57 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:50:27 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:50:27 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:50:48 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:50:48 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 11:50:54 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 11:50:54 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 8:29:33 PM JowiHue Warning Warning: Please check parameters with documentation?
                    10/6/2020 8:29:33 PM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/6/2020 8:55:05 PM JowiHue Info JowiHue Plugin closing now. Thanks for using it :-)
                    10/6/2020 8:55:13 PM JowiHue Info settings loaded
                    10/6/2020 8:55:13 PM JowiHue Info Starting plugin JowiHue 4.0.2.5 on Linux
                    10/6/2020 8:55:13 PM JowiHue Info Logfile is set to /usr/local/HomeSeer/Logs/JowiHue.log
                    10/6/2020 8:55:14 PM JowiHue Info No bridges found
                    10/6/2020 8:55:25 PM JowiHue Info Found new bridge Hue Bio at 192.168.0.10:80
                    10/7/2020 1:00:01 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/7/2020 1:00:01 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/7/2020 1:10:02 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/7/2020 1:10:02 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    10/7/2020 9:16:18 AM JowiHue Info JowiHue Plugin closing now. Thanks for using it :-)
                    10/7/2020 9:17:32 AM JowiHue Info No bridges found
                    10/7/2020 9:17:32 AM JowiHue Info settings loaded
                    10/7/2020 9:17:32 AM JowiHue Info Starting plugin JowiHue 4.0.2.5 on Linux
                    10/7/2020 9:17:32 AM JowiHue Info Logfile is set to /usr/local/HomeSeer/Logs/JowiHue.log
                    10/7/2020 9:17:44 AM JowiHue Info Found new bridge Hue Bio at 192.168.0.10:80
                    10/7/2020 9:31:17 AM JowiHue Warning Warning: Please check parameters with documentation?
                    10/7/2020 9:31:17 AM JowiHue Error Error: (PluginFunction): calling PagePreLoadBridges: Exception has been thrown by the target of an invocation.
                    Regards, Jacob
                      Jacob,
                      Looking at the errors shown, you are not using the Add new bridge page, but the bridge maintenance page? You cannot use this page until indeed a new bridge has been added? Is this correct? I will change this page to make a remark on this when opened without bridges added.
                      Are you aside from this also using the add bridges page entry? See image for this.
                      Wim
Name:	2020-10-07 15_23_49-Log.png
                      -- Wim
                        Hi Wim, It makes no difference. When I choose Add new bridge from pop up window as you show above. The next screen is step 1 and so forth. I can try to remove the plugin again and then add it again. I just did that and the result is the same. Regards Jacob
                          Hi Wim, I see that you are from Holland. If you are interessted and use paypall then I would like to pay you for checking my homeseer setup with you. We can make and skyp call or wathever suits you. My problem is that I have upgraded my HS 3 R Pi to 4. And in that procedure i have created the network and z-wave as i understand it should be, but it seems wrong:
                          Look here:
                          I am planning to switch from Fibaro HC4 to Homeseer. And this installation is for the moment just the presystem, so I can reset it etc. and start from scratch if that would be a solution. Regards, Jacob
                            You say you upgraded from HS3 to HS4. Was the JowiHue plugin (HS3 version) running on the HS3 installation? You did no convert from the existing installation but started from scatch?
                            I think a log of the plugin could be helpful here in trying to determine what is happening. I double checked here with a maiden installation. It finds the bridge, just like in your log:
                            But in my case, opening the add new bridge page sees the new bridges (all 3 of them) and lets me add it without an issue.
                            In your case something goes wrong. I am running Windows, you are running Linux, so maybe there is a difference here I do not know of yet (would not be the first time :-))
                            Could you create a detailed trace for me with the following steps:
                            1. go to the settings page of the plugin and enable verbose tracing and log to file options
                            2. stop the plugin and restart it
                            3. let the plugin run for 5 minutes and then goto the add bridges page. Then press the next button.
                            4. Disable the verbose tracing and log to file options.
                            5. Find the JowiHue.log file in the /Logs subdirectory of the HS installation directory
                            6. Send this file to JowiHue at ziggo dot nl?
                            As for the ZWave issue you mention, I probably am not much help. I have ZWave running here, it has been stable for a long time, for only a few devices. I do not tinker much with that part. Maybe someone else can jump in here, or otherwise put this question on the ZWave board?
                            Wim
                            -- Wim
                              Hi Wim, Thanks for your answer. I will perferm your advice tomorrow evening as I am occupied until then. I do not remember how I did with the Jowihue HS4 plugin, but yes I did buy a HS3 jowihue for both my Pi and windows installation. I will try to power up my homeseer on windows to see if this platform has the same issue. Comming back later. Regards Jacob
