Either I'm doing something wrong or discovered a new quirk....
I've successfully made local scenes in the PI, when I trigger them they execute properly against the lights assigned to the group they are in. Each one of these scenes had the Brightness level set to 50%.
The quirk is with the Light Group device created in HS4. If I trigger a scene assigned to the light group it executes perfectly... except the dim level value for the group device indicates Off. Again the lights are physically lit and at the right level.
Then almost exactly 42 to 43 seconds later the dim value jumps to 50%. Again, the actual light level of the lights remain unchanged.
The problem is during that delay of 42 seconds I am unable to change the dim level of the group programmatically from another event. Once the Dim setting corrects itself in the group device then my other dim events work perfectly.
Thoughts?
Thoughts?
