Hi Guys,
On a steep learning curve on Zigbee and Deconz (90% of my devices are Zwave or wifi) and I can't see to find a straight answer on something. I have recently bought some of the Sonoff SNZB-02 Temperature and Humidity Sensors to use to activate exhaust fans in bathrooms.
I have these loaded up in Deconz by the default method (with the lasted Decon Version), but the batteries seem to go flat FAST. I have another Zigbee Temp and humidity sensor from another vendor, and the battery has lasted over 5 mths and looks good as a percentage.
Is there a way to adjust the transmission interval on ZigBee devices? This device seems to update every 5 mins. The one with the better battery seems to be 15mins.
I also think that you can transmit on a % change of temp or humidity, rather than whenever a small change is triggered. This would be my preferred trigger, as it mainly should trigger when there is a big change in Humidity.
I know this isn't specifically a JowiHue question, but the HomeSeer Forums have always treated me well!!!
Any help or tips greatly appreciated!!!
