JowiHue plugin issue with DeConz bridge - Optional to limit command queue
    Hi Guys,
    I have a HS4 installastion that use smart light control via a DeCoinz ConBee I gateway.
    JuwiHue HS4 plugin installed.
    Approx 110 Smart Lights (Ikea Traadfri) and a few sensors and switches.
    This halloween I desided to do Scenes and Animation from the JowiHue plugin.
    In it self this is works great, issue is that the Deconz and Conbee gateway cant keep up.
    DeConz has a hard coded limit of 20 sequential commands, more than that JowiHue plugin throws error and scenes and animation fails to execute as expected.
    I would much like to se the option to limit the command queue, or that the plugin it self is able to "sense" that it is DeConz gateway conneted setting the limits not to flood DeConz with commands.
    Would this be possible to implement??
    Note!! I have discussed this with DeConz developers and they can not change this.
    I would like to know what the errors are?
    The plugin is already limiting its speed to ca. 10 commands per second max (following the guidelines of the Philips Hue bridges) and even more slow when a command to groups is send. This has been in the plugin for several years. But overtime I have adjusted some of the timings based on my own environment and experiences. So maybe I have stepped on some boundaries here?
    Are you running the latest version of the plugin, and could you post some of the errors thrown (preferably in a verbose logging?)
    Wim
    -- Wim
      Hi Wim,
      Thanks for getting back to me
      Yes latest HS4 native plugin, with the latest DeConz version.
      Issue is sequention command, not max per second and so on.
      This only happens when i "stress" JowiHuw and DeCOnz, not day to day use.
      This is the thread on GitHub on issue:
      https://github.com/dresden-elektroni...in/issues/3561
      I can create logs, I need a bit of time to make that happen. I will get back to you on that.
        Verbose log when runing multiple scenes and animations via JowiHue plugin.
          That is not the verbose log I think. You will find the results of verbose logging in the JowiHue.log file in \Logs.
          This error is different from what you posted in Github. The error you are looking at now seems to point to a bad scene maybe? If I have the vebose log behind that I probably can point to the scene having this issue. The unexpected result in Json as posted in Github is a timings issue. When I can have a look at the verbose log of that I can check the timing....
          -- Wim
            Ok, only sent verbose to console.
            I'll enable log file.
              This is a part of log file, if you want me to send you entire file let me know
              13:46:32.2494047 -- (HSPI.OnSettingsLoad) starting
              13:46:37.0118238 -- (UPNP.UDPListener) 5 blocks found to process
              13:46:37.0128207 -- (UPNP.Bridgescan) Debug: End search for bridges
              13:46:49.3208642 -- (WebCommander.HandleWebQueue) Dequeue command: json {"attr":{"id":"105","lastannounced":"2020-11-09T13:40:37Z","lastseen":"2020-11-12T12:46Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb GU10 W 400lm","name":"Light 105 - Bad Dusj","swversion":"1.2.214","type":"Dimmable light","uniqueid":"90:fd:9f:ff:fe:0e:ec:40-01"},"e":"changed","id":"105","r":"lights","t":"event","un iq ueid":"90:fd:9f:ff:fe:0e:ec:40-01"} new queue size is 0 on 00212EFFFF022EBD
              13:46:56.8844692 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"4","r":"sensors","state":{"lastupdat ed" :"2020-11-12T12:46:56.878","temperature":2228},"t":"event","uniqueid": "00:17:88:01:06:f6:df:56-02-0402"} new queue size is 0 on 00212EFFFF022EBD
              13:47:01.1688085 -- (BridgeApi.GetJsonCommand) Sendrequest took 19 millisconds Thread: 0
              13:47:01.2078129 -- (Mylights.Comparestate) Light reachable change
              13:47:01.2118130 -- (Mylights.UpdateLight) Debug: Light 101 - Bad Spa is reachable again
              13:47:01.2298244 -- (Mylights.UpdateLight) UpdateLight setting device 3095 On/off To off
              13:47:01.2838242 -- (Mylights.Comparestate) Light reachable change
              13:47:01.2908261 -- (Mylights.UpdateLight) Debug: Light 18 - Kichen is unreachable
              13:47:01.2908261 -- (SQLiteFunctions.UpdateUsage) Usage rows updated: 1
              13:47:01.3008228 -- (SQLiteFunctions.UpdateUsage) Usage rows updated: 1
              13:47:01.3118248 -- (Mylights.Comparestate) Light reachable change
              13:47:01.3148245 -- (Mylights.UpdateLight) Debug: Light 23 - Living Room Table is reachable again
              13:47:01.3238237 -- (Mylights.UpdateLight) UpdateLight setting device 2875 On/off To 10
              13:47:01.4468417 -- (Mylights.Comparestate) Light reachable change
              13:47:01.4578426 -- (Mylights.UpdateLight) Debug: Light 59 - Living Room Hall is unreachable
              13:47:01.5018366 -- (JowiHueUtils.EnergyProcessThread) 12.11.2020 13:47:01 Started usage for Light 23 - Living Room Table
              13:47:01.5118378 -- (SQLiteFunctions.UpdateUsage) Usage rows updated: 1
              13:47:01.5118378 -- (JowiHueUtils.EnergyProcessThread) Debug: EnergyProcessThread: Switched off - Total usage of Light 59 - Living Room Hall is now 185 Days, 19 Hours and 57 minutes(16055840 seconds)
              13:47:01.5268399 -- (SQLiteFunctions.UpdateUsage) Usage rows updated: 1
              13:47:01.5968460 -- (Mylights.Comparestate) Light reachable change
              13:47:01.6038502 -- (Mylights.UpdateLight) Debug: Light 96 - Bad Speil figur is unreachable
              13:47:01.6288617 -- (MyGroups.UpdateGroup) Group Stue Hall Kveld has been updated
              13:47:01.6368488 -- (MyGroups.UpdateGroup) Group Hall Inngang Night has been updated
              13:47:01.6458478 -- (MyGroups.UpdateGroup) Group Stue Lampet has been updated
              13:47:01.7188585 -- (MyGroups.UpdateGroup) Group Stue Hall has been updated
              13:47:01.7288582 -- (MyGroups.UpdateGroup) Group Stue Hall Night has been updated
              13:47:01.7438641 -- (MyGroups.UpdateGroup) Group Hall Inngang has been updated
              13:47:01.8008892 -- (DeCONZCache.UpdateBridgeCache) exit; Update running =False
              13:47:15.8809464 -- (WebCommander.HandleWebQueue) Dequeue command: json {"attr":{"id":"65","lastannounced":"2020-10-27T14:05:11Z","lastseen":"2020-11-12T12:47Z","manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb GU10 W 400lm","name":"Light 65 - Entrance Hall","swversion":"1.2.214","type":"Dimmable light","uniqueid":"90:fd:9f:ff:fe:1f:9d:12-01"},"e":"changed","id":"65","r":"lights","t":"event","uni qu eid":"90:fd:9f:ff:fe:1f:9d:12-01"} new queue size is 0 on 00212EFFFF022EBD
              13:47:17.3100540 -- (JowiHueActions.OnRunAction) OnRunAction started for Halloween Halloween - Lys Stuebord every 10 min
              13:47:17.3400566 -- (AnimationWorker.Execute) Debug: Execute: Animation Halloween Stuebord with 9 steps and 8 different inner loops
              13:47:17.3400566 -- (AnimationWorker.SaveSettingsPerLight) `Saving lightssettings before start of animation 13:47:17
              13:47:17.3780554 -- (AnimationWorker.Execute) Start of animation Halloween Stuebord
              13:47:17.3920600 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: starting loop 0 from sequence 1 till 9
              13:47:17.3920600 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop no 1 in loop 1
              13:47:17.3930617 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:17
              13:47:17.4210621 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:17.4230631 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:17.4230631 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:17
              13:47:17.4230631 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:17
              13:47:17.4240616 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:17.4240616 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:17.5260652 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:17
              13:47:17.5270644 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:17.5280642 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:17.5280642 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 200 milliseconds 13:47:17
              13:47:17.7290795 -- (AnimationWorker.ExecuteLoop) Starting new loop
              13:47:17.7290795 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: starting loop 1 from sequence 1 till 2
              13:47:17.7290795 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:17
              13:47:17.7300791 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:17.7310788 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:17.7310788 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:17
              13:47:17.8320953 -- (AnimationWorker.ExecuteLoop) Starting new loop
              13:47:17.8320953 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: starting loop 2 from sequence 1 till 3
              13:47:17.8320953 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop no 1 in loop 3
              13:47:17.8320953 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:17
              13:47:17.8330927 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:17.8340936 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:17.8340936 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:17
              13:47:17.9351010 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:17
              13:47:17.9351010 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:17.9360942 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:17.9371008 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 200 milliseconds 13:47:17
              13:47:18.1381100 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:18
              13:47:18.1381100 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:18.1391106 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:18.1401106 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:18
              13:47:18.2421192 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:18
              13:47:18.2431192 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:18.2441166 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:18.2441166 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:18
              13:47:18.3451230 -- (AnimationWorker.ExecuteLoop) Starting new loop
              13:47:18.3451230 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: starting loop 3 from sequence 1 till 4
              13:47:18.3451230 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:18
              13:47:18.3461333 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:18.3471255 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:18.3471255 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 200 milliseconds 13:47:18
              13:47:18.5481417 -- (AnimationWorker.ExecuteLoop) Starting new loop
              13:47:18.5481417 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: starting loop 4 from sequence 1 till 5
              13:47:18.5481417 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop no 1 in loop 5
              13:47:18.5491403 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:18
              13:47:18.5491403 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:18.5501431 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:18.5511437 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:18
              13:47:18.6521519 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:18
              13:47:18.6521519 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:18.6531528 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:18.6541516 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 200 milliseconds 13:47:18
              13:47:18.8551673 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:18
              13:47:18.8551673 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:18.8561627 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:18.8571702 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:18
              13:47:18.9631729 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:18
              13:47:18.9681725 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:18.9701708 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:18.9721767 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:18
              13:47:18.9741886 -- (JowiHueActions.OnRunAction) OnRunAction started for Halloween Halloween - Lys Stuebord every 10 min
              13:47:18.9751842 -- (AnimationFunctions.TriggerAnimation) Animation Halloween Stuebord is already running, command ignored
              13:47:19.0731829 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:19
              13:47:19.0731829 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:19.0741796 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:19.0751863 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 200 milliseconds 13:47:19
              13:47:19.2762034 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop no 2 in loop 5
              13:47:19.2762034 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:19
              13:47:19.2762034 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:19.2782062 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:19.2782062 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:19
              13:47:19.3792057 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:19
              13:47:19.3902080 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:19.3912065 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:19.3912065 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 200 milliseconds 13:47:19
              13:47:19.5932312 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:19
              13:47:19.5932312 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:19.5942253 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:19.5952230 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:19
              13:47:19.6962294 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:19
              13:47:19.6962294 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:19.6972298 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:19.6982320 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:19
              13:47:19.7992387 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:19
              13:47:19.7992387 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:19.8012391 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:19.8012391 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 200 milliseconds 13:47:19
              13:47:20.0022510 -- (SceneTrigger.Execute) starting scenesAction 1 13:47:20
              13:47:20.0022510 -- (SceneTrigger.ExecuteDetail) Error: :Scenedetail: Object reference not set to an instance of an object.
              13:47:20.0032534 -- (SceneTrigger.ExecuteDetail) DisplayObjectInfo ------------------ Empty object send -----------------------
              13:47:20.0042539 -- (AnimationWorker.ExecuteLoop) Debug: ExecuteLoop: Waittime: 100 milliseconds 13:47:20
                There is something wrong in the scenes that are starting. Is the name of the scene always "1"? It looks like this scene is incomplete somehow? Could you check on thë details of the scene that should start?
                -- Wim
                  Another user comes with a similar issue... are you running on Linux too maybe?
                  -- Wim
                    Hi Wim,
                    Environment HS4 running on Windows Server 2019 Standard.
                    HS versjon 4.0.9.0
                    JowiHue plugin the latest available. 4.0.3.1a
                    Scene example none of them is names 1:
                    Same brightness and transition time on all colors.
                    And this is animation for scene above:
                    This setup makes suire th RGB lamp switch colors and blinks.
                    Last scene:
                    This scene uses 3 Ikea warm/cold white bulbs, making the change from cold to warm ins a random sequense.
                    And animation to the scene over:
                    Both scenes and animation stresses DeConz, at runing one or both this animatons via HS events triggers error seen in log file and console.
                    Scene overview:
                    Animation overview:
                      Hmm , I did a manual test of scenes and animations directy in plugin, and now I see that my configuratio isnt there anymore.
                      Perhaps change to plugin?
                      All presets been set to "new preset" not warm white, reading, cold, or colors anymore.
                      Guess that is the reason for the error seen in log.
                        I think you need to relax the animation a bit. Using 0,1 second for a step is officially the limit for commands to be send. Will have to check on the command structure to be more strict I suppose. But I think the first priority for now should be checking why the plugin is throwing errors on the scenes, as those error are before any command has been sent.
                        Could you send me the JowiHue.db file, that is in the \Data directory? I am wondering if anything is wrong in there? Send it to jowihue at ziggo dot nl?
                        -- Wim
                          Ok, no problem changing not be so aggressive.
                          db file sent. Let me know if you doint receive file.
                          /Kenneth
                            I sent a zip file with content of backup directry to you as well.
                              All received... will get back to you
                              -- Wim
