HS4 - can't configure animation?
    Team,
    When I go to the JowiHue/Creativity-settings/Animation/Add-new-animation screen, I see the following:
    Click image for larger version  Name:	Screenshot 2020-12-01 at 14.34.30.png Views:	0 Size:	51.8 KB ID:	1437373
    From this point it doesn't matter which name I type of checkboxes I check, this is and remains the only user interface that appears. When pressing enter on the "name" field the screen refreshes and I see the exact same screen as above.
    In the log, this message appears the second I click the + sign to add an animation:
    Error: (GetCreativityPage):Issue getting creativity page during editanimation The given key was not present in the dictionary.
    It also appears when it wants to save the page (press enter in the name field)
    HS4.1.9, latest JowiHue plugin.
    Is this a known issue?
    I have checked it here just now. I have changed a lot lately in the animations so it could very well show an issue. But here I do not see this issue...
    Below the check boxes a select box should be shown with scenes to select. You have scenes right? If there are no scenes yet this could go wrong maybe.
    Is it possible you create a verbose logging with to logtofile set (in settings) for me?
    Just set the options and try to add an animtion. Also send me an image of the scenes screen?
    You can send the info to jowihue at ziggo dot nl?
    Wim
    -- Wim
      Wim
      I do have scenes configured
      Will send the logs.
        Since the last update it is working!
          One of those miracles of this period
          -- Wim
