All:
I've got deCONZ 2.09 running and bought 6 devices to get it up and running - all in a 120 sq ft room. I see the routes coming and going frequently, the paths between two bulbs literally 1 ft apart red/bad, sensors never seem to reconnect after an app restart. And of course the few commands I've attempted to send haven't worked, the node goes from available to offline. This is a raspberry pi 3b+ using the prebuilt image from the phoscon website so I can't have messed up any pi os settings. I'm wondering if anyone else had similar issues and found an obvious fix (maybe serial port baud rate or i2c baud rate????). Thanks in advance.
I'm coming from zwave on a znet which was rock solid for at least 5 years.
