*update* - I fixed this myself: The issue was in the status graphics range - your minimum is too high - 870 vs my current reading of 854 (I'm at 5000 ft - is that it?)
I see a post on here about the Temperature not showing and then 'just' showing up - so as time goes on this may be a non-issue but....
For now the Air Pressure is not showing up. I know the plugin is capable - I've created/deleted the hub several times as I am starting with a new set up. The hub is Raspbee II/deCONZ. The deCONZ app shows the pressure and has been reading now for 2 days. Is there anything I can do to try to kick/harass/motivate the plug in to get this value? I've also got Hue Essentials on my phone and it shows the air pressure, so that eliminates the hub as a problem...The other values appear to be reading correctly.
