Hi Wim,
I'm using Aqara temp/humidity sensors, they are fantastic and inexpensive workhorses. Like many Zigbee devices, they pre-programmed to only report data when an internal sensor changes value.
As you can see below, I've got one that is operating fine, but the battery value has not been updated since inclusion. I know that the lithium coin cells have long operating life and will tend to report 100% until they fall off dramatically one day.
My question is this: I've check the device definition in HS4 and made sure that "Last Change Time Updates on Status Change Only" is unchecked on both the parent and battery child device, yet as you can see the time doesn't change. Is there something that can be done in deConz to program a cluster to make sure that battery updates are sent along with the other data reports?
