Hi, I'm trying to add a Hue Bridge to HS4 but the plugin is saying "No New bridges found."
When I try to specify the IP of the bridge I get the same message.
In the logs I see this:
1.19.2021 22:08:07 JowiHue Debug Debug: (Bridgescan) :End search for bridges
1.19.2021 22:08:03 JowiHue Info UPNP-backdoor no valid response from IP in INI file, Please check IP seems to be bridge, but not a correct response (is bridge updated to latest level?)
1.19.2021 22:08:03 JowiHue Debug Debug: (BridgeCheckIP) :IP address 192.168.xxx.xxx not responding: Den eksterne serveren returnerte feilen (404) File not found.
I have contact with the bridge from the Hue app on my phone and can control the light from there without problems
JowiHue version: 4.0.3.8
HS4 Pro Edition 4.1.10.0 (Windows)
What should I try?
Thanks in advance
What should I try?
Thanks in advance
