I have the same - appears to be a Samjin sensor - about every min the log has :
10:25:44.8096483 -- (DeCONZCache.UpdateBridgeCache) exit; Update running =False
10:26:12.3615037 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"16","r":"sensors","state":{"lastupda ted ":"2021-02-04T18:26:12","temperature":2176},"t":"event","uniqueid":"00: 15:8d:00:04:27:23:4a-01-0402"} new queue size is 0 on 00212E054189
10:26:12.3635039 -- (MySensors.UpdateSensorDevice) UpdateSensors updated Master 2 type ZHATemperature To 71.17
10:26:12.3947039 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"17","r":"sensors","state":{"humidity ":2 588,"lastupdated":"2021-02-04T18:26:12"},"t":"event","uniqueid":"00:15:8d:00:04:27:23:4 a-01-0405"} new queue size is 0 on 00212E054189
10:26:12.3947039 -- (MySensors.UpdateSensorDevice) UpdateSensors updated Master 2 type ZHAHumidity To 25.88
10:26:17.9733151 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"12","r":"sensors","state":{"alarm":t rue ,"lastupdated":"2021-02-04T18:26:17","lowbattery":false,"tampered":false},"t":"event ","uniqueid":"00:0d:6f:00:05:75:ec:df-01-0500"} new queue size is 0 on 00212E054189
10:26:32.4341439 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"19","r":"sensors","state":{"lastupda ted ":"2021-02-04T18:26:32","temperature":2181},"t":"event","uniqueid":"00: 15:8d:00:02:2f:d1:f0-01-0402"} new queue size is 0 on 00212E054189
10:26:32.4341439 -- (MySensors.UpdateSensorDevice) UpdateSensors updated Pilates type ZHATemperature To 71.26
10:26:32.4733444 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"20","r":"sensors","state":{"humidity ":2 978,"lastupdated":"2021-02-04T18:26:32"},"t":"event","uniqueid":"00:15:8d:00:02:2f:d1:f 0-01-0405"} new queue size is 1 on 00212E054189
10:26:32.4733444 -- (MySensors.UpdateSensorDevice) UpdateSensors updated Pilates type ZHAHumidity To 29.78
10:26:32.4889445 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"21","r":"sensors","state":{"lastupda ted ":"2021-02-04T18:26:32","pressure":825},"t":"event","uniqueid":"00:15:8 d:00:02:2f:d1:f0-01-0403"} new queue size is 0 on 00212E054189
10:26:54.2899047 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"3","r":"sensors","state":{"lastupdat ed" :"2021-02-04T18:26:54","temperature":2640},"t":"event","uniqueid":"00: 0d:6f:00:05:75:ec:df-01-0402"} new queue size is 0 on 00212E054189
10:26:54.3149061 -- (MySensors.UpdateSensorDevice) UpdateSensors updated Temperature type ZHATemperature To 79.52
10:27:14.4750592 -- (BridgeApi.SendRequest) sendrequest total took 9
10:27:14.4750592 -- (BridgeApi.GetJsonCommand) Sendrequest took 9 millisconds Thread: 0
10:27:14.5540638 -- (DeviceCreation.CreateNewDevice) starting Sensors
10:27:14.5540638 -- (DeviceCreation.CreateNewDevice) Debug: CreateNewDevice:start creating sensor device for Temperature ID=15
10:27:14.7670759 -- (MySensors.UpdateSensor) Debug: Error: checking sensorconfig battery
System.NullReferenceException(0x80004003): Object reference not set to an instance of an object.
at HSPI_JowiHue.MySensors.UpdateSensor(String id, Sensorstate state, SensorConfig config, String uniqueid)
**************************** Object info *****************************
"state": {
"lastupdated": "2021-02-04T17:55:30",
"vibration": false,
"orientation": [
18,
-1014,
12
"config": {
"on": true,
"battery": 62,
"reachable": true
"name": "Temperature",
"type": "ZHAVibration",
"modelid": "multi",
"manufacturername": "Samjin",
"uniqueid": "28:6d:97:00:01:0a:d1:66-01-fc02",
"ep": 1,
"etag": "d42a98dbc235d7639121b0a321a0a539"
************************* End Object info ***************************
10:27:14.7680760 -- (MySensors.UpdateSensor)
"vibration": false,
"orientation": [
18,
-1014,
12
"state": {
"vibration": false,
"orientation": [
18,
-1014,
12
"config": {
"on": true,
"battery": 62,
"reachable": true
"modelid": "multi",
"ep": 1,
"vibration": false,
"orientation": [
18,
-1014,
12
