After sorting out my switches temporarily, I decided to do some other clean up, and I've done some renames this evening. Now, when I start up the PlugIn, I'm seeing the errors below. Things SEEM to be working at the moment. The first and last are the most confusing ones, as they're saying to check a device against itself. For the other 2, the device it suggests removing has the 'Dim Up' and 'Dim Down' buttons, and the main device has the Dim slider, so I can see removing that would make sense, but it also has the 'Blink' and 'Alert' buttons, which I don't see the logic in moving - or am I missing something?
As usual, logs etc. if you want them.
G
Both devices are pointing to the same light. It is adviced to remove the device holding feature ref:1730
Warning: please check Office Fan Unit (Fan) ref: 1730 and Office Fan Unit ref: 1730
Both devices are pointing to the same light. It is adviced to remove the device holding feature ref:1832
Warning: please check Light - Dining Room Center Light Extra ref: 1833 and Light - Dining Room Center Light ref: 1832
Both devices are pointing to the same light. It is adviced to remove the device holding feature ref:1824
Warning: please check Light - Dining Room Center 2 Extra ref: 1825 and Light - Dining Room Center 2 ref: 1824
Both devices are pointing to the same light. It is adviced to remove the device holding feature ref:770
Warning: please check Living Room South Color ref: 770 and Light - Living Room South Color ref: 770
G
