Hi Wim
The Ikea fyrtur blinds do not open or close when pushing the Open and Close buttons i Homeseer 4. When I use the Ikea tradfri hub the blinds works. I have also used the zigbee2mqtt for testing the blinds and it works without problem with this program (https://www.zigbee2mqtt.io/devices/E1757.html).
I also used DeConz GUI for testing following this procedure: https://github.com/dresden-elektroni...ment-754161432 and the blinds was opening and closing with status sucess so I do not think this is a network problem.
In Deconz I see the Fyrtur blind is connected to the Ikea signal amplifier which follow the blind when buying.
I followed your advice from your posting here: https://forums.homeseer.com/forum/hs4-products/hs4-plugins/lighting-primary-technology-plug-ins-aa/jowihue-w-vuyk-aa/1398707-using-a-ikea-smart-blind-fyrtur-or-kadrilj and tried to manually bind the blind to the coordinator without success. But I see the current position for windows covering devices being reported when manually opening and closing from Deconz GUI.
JowiHue configuration Open/Close device
JowiHue 4.0.4.2
Deconz 2.09.03
Hope you can help me.
Harald
Feature configuration Rullegardin soverom1, root Open/Close Details Rullegardin soverom1, root Open/Close [TABLE] [TR] [TD]On bridge id[/TD] [TD]00212E0424B7[/TD] [TD]ID[/TD] [TD]19[/TD] [/TR] [TR] [TD]Curtain manufacturer[/TD] [TD]IKEA of Sweden[/TD] [TD]Curtain model[/TD] [TD]FYRTUR block-out roller blind[/TD] [/TR] [TR] [TD]Curtain Type[/TD] [TD]Window covering device[/TD] [TD]Curtain Unique ID[/TD] [TD]68:0a:e2:ff:fe:64:f8:99-01[/TD] [/TR] [TR] [TD="colspan: 4"] [/TD] [/TR] [/TABLE] Configuration options Rullegardin soverom1, root Open/Close maximum open maximum close Feature Rullegardin soverom1, Battery Details Rullegardin soverom1, Battery [TABLE] [TR] [TD]On bridge id[/TD] [TD]00212E0424B7[/TD] [TD]ID[/TD] [TD]17[/TD] [/TR] [TR] [TD]Sensor manufacturer[/TD] [TD]IKEA of Sweden[/TD] [TD]Sensor model[/TD] [TD]FYRTUR block-out roller blind[/TD] [/TR] [TR] [TD]Sensor Type[/TD] [TD]ZHABattery[/TD] [TD]Sensor Unique ID[/TD] [TD]68:0a:e2:ff:fe:64:f8:99-01-0001[/TD] [/TR] [TR] [TD="colspan: 4"] [/TD] [/TR] [/TABLE] Reset Graphic values for all features belonging to devices [B]Window covering device[/B] **************************** Object info ***************************** { "etag": "71da1b94db492152171a64aa0b65212b", "hascolor": false, "lastannounced": "2021-02-20T18:10:57Z", "lastseen": "2021-02-20T18:29Z", "manufacturername": "IKEA of Sweden", "modelid": "FYRTUR block-out roller blind", "name": "Rullegardin soverom1, root", "state": { "bri": 254, "lift": 100, "on": true, "open": false, "reachable": true }, "swversion": "2.2.009", "type": "Window covering device", "uniqueid": "68:0a:e2:ff:fe:64:f8:99-01" } ************************* End Object info *************************** [B]ZHABattery[/B] **************************** Object info ***************************** { "config": { "on": true, "reachable": true }, "ep": 1, "etag": "506e25b90d43631abcefb886b4de43d0", "lastseen": "2021-02-20T18:29Z", "manufacturername": "IKEA of Sweden", "modelid": "FYRTUR block-out roller blind", "name": "Rullegardin soverom1, root", "state": { "battery": 98, "lastupdated": "2021-02-20T18:16:05.406" }, "swversion": "2.2.009", "type": "ZHABattery", "uniqueid": "68:0a:e2:ff:fe:64:f8:99-01-0001" } ************************* End Object info ***************************
JowiHue 4.0.4.2
Deconz 2.09.03
Harald
