Willem,
I think this dimmer is not yet supported through deCONZ. To make the devs support it you need to put in a device request in on the githu site. Here you will find nmore info on how to put in a device request:https://github.com/dresden-elektroni...Device-Support. You need to supply all info they ask for and they will pick it up form there.
Wim
Jasco smart dimmer and switch
Wim,
Recently purchased a Jasco smart dimmer 45852 with energy monitoring
Joined the device through your PI Phoscon.
Dimmer and on/off worked fine, however no representation for Watts & Kw/hr. in status and graphics to use as triggers etc.
[ATTACH]n1466202[/ATTACH]
The Jasco switch with the same Energy monitoring promise is Jasco 45853 smart switch.
Need your help to unscramble this issue.
Thanks for your contributions.
Regards,
Willem
Tags: None
