Jowie Hue generating errors in the log
    I'm getting the following log entries. How can I debug please?
    JowiHue Error: (UpdateLight):Exception while executing GetDeviceWithFeaturesByRef - devRef : 0 - message : Error while converting 0 to HsDevice : Object reference not set to an instance of an object.
    JowiHue Error: (CreateFeatureLight):Error occurred during creation Of feature during Step Handling light creating new feature PED Object reference not set to an instance of an object.
    I am thinking here it could be very much related to the other post regarding the GLEDOPTO bulb. The plugin struggles with the creation of the device there so it is not finishing it due to the error. How many of these lights do you have that keep creating the CT devices? If it is only one, could you try stopping the plugin and deleting the device and its features, and then restart the plugin? See if the error clears up then. Otherwise, send me a log file with tracing? Follow these steps for creating a log:
    1. Make sure you are running the latest version of the plugin (4.0.4.4)
    2. In the settings of the plugin, enable verbose logging (not Debug!) and log to file options
    3. Stop and start the plugin, so I can see the start of the plugin
    4. Let the plugin run until the error is logged
    5. Disable the verbose logging and log to file options
    6. Send the file \Logs\JowiHue.log to jowihue at ziggo dot nl?
    Wim
    -- Wim
      chimera Are you able to create log?
      -- Wim
        Thanks Wim for your help. Yes I've just sent you a log file.
