Hi,
I have this "bad" device I can't seem to fix. It's a Philips Hue motion sensor. I got 7 or 8 of them and all went in fine except one. They were added to a Raspbee II, not on a Philips Hue bridge.
Here is the device:
It seems a bridge always remember that sensor. I've removed it from the Raspbee (to which it was initially added) several time. It no longer shows in deCONZ or Phoscon afte removal.
That particular device was returned to seller and is no longer a visible device in Raspbee nor a identifiable device. Yet, even after deleting the device in HS, it re-appears. Even more odd, it now shows under the Philips Hue bridge:
Why would it be visible under the Philips bridge when I never, ever tried to add it to that bridge?
If I try to remove it from the above screen, will that clear it from both the Hue bridge and HS?
Here is the device:
