Having some issues with the Philips Hue motion sensors and need to better understand the available settings in the JowiHue page, their respective values and how to make sure those settings reach the device.
Lets look at a particular sensor, a Philips SML001 that includes motion, temperature and lumen sensors:
For this type of sensor, I get 2 settings and a LED control for the motion sensor and 1 setting for the temperature sensor:
Motion settings:
Temperature settings:
My understanding of the "Delay nomotion after motion ends" is that the value express the amount of time, in minutes, for the sensor to report no movement back to the plugin after the movement has stopped. I don't remember the initial value. When I initially installed it, I set it to 2, assuming 2 minutes. That value was not enough so I tried to set it to 5, again assuming minutes. The setting doesn't seem to have reached the device, except for the LED setting.
To set this up, I made sure to wake up the device before saving the value in HS. Yet, I'm not seeing the change of behaviour of the sensor although the LED setting seems to have made it thru.. It does flick once in a while when movement starts. but that is not consistent. At this point, the behaviour is after about 1 minute it will report new movement. What am I doing wrong?
For the "Sensitivity motion", the page indicate a value of 0 to 2 is required. I'm assuming 0 is the most sensitive and 2 the least. Is that correct?
For the "Correction temperature value", what is the range, single digit or with a decimal, and can we input a negative value?
And finally, how to make sure these values reach the device?
Motion settings:
