I see the value JowiHue has set for Open is 0, and the value for Closed is 100. This is opposite from other window covering devices I've seen in HomeSeer, which all have used 0 for the Closed value. So I'm just wondering if this is the expected behavior for JowiHue?
Reason I ask is I'm running into issues when adding this device to HomeKit using @jvm's Homebridge-HomeSeer4 plugin. In the Home app the device states are backward, so it is apparently expecting opposite values for open / closed. Wanted to check here before I go digging into the Homebridge plugin code...
PS Running JowiHue v4.0.4.4 and HS4 Pro v4.1.15.0 on Windows
