SNZB-01 switch support
    Wim, any chance we could see support for the Sonoff SNZB-01 pushbutton switch? Deconz supports it, but when added, in HS it just has a set of values that change depending on how the button is pushed.
    The values are:
    1002 is single click
    1004 is double click (On)
    1003 is 3 sec hold
    The value never returns to 0, it stays on whatever the last press was, but the update time changes when the button is pressed.
    That is all the pushbutton does. All switches work that way, it sets the value of the button used. If you need an event that responds when a button is pressed, make sure to trigger it on "Has its value SET to", not changed....
    -- Wim
