Hi Wim, hope all is well.
Ran into a very perplexing problem that took me a couple of days to figure out. I'll try to summarize...
I have a script that I use to control dimmable Homeseer objects/devices via events triggered by central scenes. In order to use the CAPI Control Handler you have to supply the Label of the control object you wish to set a value for. The below snippet works with any dimmable object in my system.
But it throws an error when I try to control a JowiHue light device.
I finally figured out that JowiHue light objects are not labeled like every other dimmable light in HS4, specifically, there's no "Dim" prefix.
Below illustrates this:
Now... I can solve this by manually altering the JowiHue light device and adding the "Dim" prefix to the status control, but I'd have to remember to do this every time I add a new light device. And I suspect if I use the reset the status/graphics option I'd lose the prefix. Or I can maintain two different scripts where the control label is just "(value)%"
But my favorite solution would be if you could add the Dim prefix so JowiHue lights look like every other light
Thoughts?
Imports System.Threading, System.Convert Sub Main(ByVal Parms As Object) Dim ParmArray() As String ParmArray = Parms.ToString.Split(ToChar(",")) Dim DeviceRef As Integer = Integer.Parse(ParmArray(0)) Dim DimValue As Integer = Integer.Parse(ParmArray(1)) '' set the device to the dim value Dim cc As HomeSeerAPI.CAPIControl = hs.CAPIGetSingleControl(DeviceRef, True, "Dim (value)%", False, False) cc.ControlValue = DimValue Dim cr As HomeSeerAPI.CAPIControlResponse = hs.CAPIControlHandler(cc) End Sub
Thoughts?
