I am not sure if I am doing something incorrectly or if there is an issue. On the Ledvance lights I have a have several events. One event sets the lights on ON. Another event sets them to DIM 50%. The on event runs just before sunset and the dim at 10pm. Then I have an off that runs later.
My issue is that the lights come on, but not to ON (100%) but instead at the last setting. I thought I was crazy so the other evening after the dim to 50% event ran, I went in and set one of lights to 75%. The lights turned off by the event that night and then last night when they came on, sure enough, the one light as at 70% and not at 100%, which I expected with ON.
I looked at my events again to make sure I did nothing wrong on the ON. I call each light instead of the group.
In the Dim event, I do use the group to dim the lights to 50%. If the dim were the issue, I would switch it to call the individual lights.
w.vuyk - does this have to do with the Ledvance lights that you are fixing somehow? Instead of ON, do I need to set to 99%? This is only the Ledvance lights. The Orsam /Cree ones work without issue.
