Reading all the different posts it dawned on me I don't have a sensor. When I go into Phoscon, there is a sensor listed - the internal sensor on the ConBee II. I went to bridge maintenance and dis a search for sensors. The log shows the search started and that it did not find anything. Is this sensor in Phoscon something I should be seeing in the plugin?
Should I see the Phoscon sensor in HS4?
HS3Pro & HS4Pro on Win2012R2
Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-WaveTags: None
Jobee The Daylight sensor is normal for phoscon and does not show up in Jowihue. Wim can explain what that device means. I have the following in HS4 in grid view. Do you have a bulb or a device in Phoscon that is a router? If not it needs one to get devices to show up in Jowihue. Look in Deconz and see if any devices have a yellow stripe on the left side of the device window. They are routers. You can click on one and on the left side a bunch of stats will show. Look for Type and it will say what it is.
The daylight sensor is an internal sensor for both the Philips Hue bridge and the deCONZ gateway. It is used internally to distinguish day or night based on sunset and sunrise. I never moved it to HS as HS already has its own sunset/sunrise settings.
Wim-- Wim
cowinger, w.vuyk - Thank you both. I now understand. A number of my bulbs are routers. I have an aerotec z-wave sensor I just need to move over to HS4. It can do % of light so I can have lights turn on and off based on the amount of light in a room. I thought this might be what the phoscon sensor did and not just sunrise and sunset.HS3Pro & HS4Pro on Win2012R2
