I have a couple of Zigbee MR16 spotlights, I wish Philips made these but Gledopto is the only company I can find that makes MR16 Zigbee bulbs.
https://www.aliexpress.com/item/1005001430888642.html
I want to be able to dim them using a Zigbee dimmer, I have both Philips Hue dimmer switches and Lutron Aurora dimmers. Dimmers and bulbs are all connected to the Hue bridge, but the bulbs don't dim properly with the dimmers.
One thing I was thinking is I could break the connection between the dimmer and the bulbs in the Hue Hub, and somehow have the dimmer control brought into HomeSeer, and use HomeSeer logic to dim the MR16 lights using the dimmer state. But I'm not sure how to do that, and I believe since the Hue Hub needs to be polled, it would probably be unusably slow.
Any other ideas for how to use the JowiHue plugin to get these MR16 bulbs dimming properly?
- They dim perfectly using the Hue app, and using HomeSeer with JowiHue, and Google voice control.
- They dim perfectly using the Zigbee dimmers when they're in RGB mode
- If I set them to "white color temperature" mode in the Hue app, and set the brightness in the app, and keep the app open, the dimmers control the bulbs just fine. But as soon as I close the app, or as soon as another Hue device changes (for example I activate a Hue motion sensor and some other light bulbs turn on), the dimmers will cause the MR16 bulb's brightness to jump all over the place. Both Philips Hue and Aurora dimmers do the same thing.
