Smartthings Arrival Sensor
    w.vuyk Wim, any chance of getting this to work in deCONZ and Jowihue? deCONZ sees it as a motion sensor but Jowihue sees it for what it is. Here is Jowihue info. Thanks
    "config": {
    "alert": "none",
    "battery": 60,
    "duration": 310,
    "on": true,
    "reachable": true
    "ep": 1,
    "etag": "3bd44993f4249038a23b2a8b1dbb0081",
    "lastseen": "2021-08-16T15:09Z",
    "manufacturername": "SmartThings",
    "modelid": "tagv4",
    "name": "Arrival Sensor",
    "state": {
    "lastupdated": "2021-08-16T15:06:03.555",
    "presence": true
    "swversion": "R860_#35",
    "type": "ZHAPresence",
    "uniqueid": "24:fd:5b:00:01:09:88:10-01-000f"
    EDIT: My bad, looks like it works somewhat correctly in Jowihue! I changed the Duration time from 310 to 60 and it seems to go to Away for a while then resorts back to Home (Home and Away are my changes to the graphics).
    Changed Duration back to 310 and it seems to stay on Away now. I read somewhere that this sensor has a 2 min. response time. Do you know anything about this? I am going to try 120 sec. and see what it does.
    EDIT2: Not sure how long it took, wasn't timing it, but the arrival sensor went back to Home. I have it in an enclosed metal can. So that is not good. That will surely mess up any events.
    To all that might want to use the smartthings arrival sensor. They do come into jowihue but they really eat the battery. I saw once where someone put the insides of the sensor into a plastic battery cabinet that could hold 2 AA batteries and with a little soldering they were running a lot longer than with the button battery. Seems like a lot to do when there are now better ways.
      I have two of these things, modified that is.
      The mod was not that difficult to do. AA batteries last forever. I would not swear but I believe the batteries are older than my 2.5 year-old cars.
      However, I did have a substantial number of false triggerings at the beginning.
      Added some logic to ignore 'departures' unless there is a valid 'exit' event and 'arrivals' without a corresponding departure.
        Larry,
        I had one tested and it worked allright, but not on a timely way. Coming home with the car could take 5 minutes for deCONZ to get a signal. For me the battery lasted three months or so. I guess it depends on the frequency of updates to send. Honestly, I stoppped using them (still have two unpacked here in a drawer) as all they really do is sending a signal every now and then, without direct reliability.
        Wim
        -- Wim
          Larry,
          Wim
          Yes I gave up on them too. They were eating batteries and were inconsistent on whether it thought it was away or home. I went to HSBuddy and that seems to work. Still messing with it. Thanks
