Hi at the moment I'm running Deconz on a Windows host with two NIC's
It doesn't look like I can specify the bind IP address for Deconz.
For some reason the plugin pulls the wrong address from Deconz then loses connection because HS isn't on the same network as the other address.
Is there a way to force to plugin to ignore the info from Deconz and use a hard coded IP?
It works correctly when I disable the NIC before I start Deconz. Interestingly the IP address of the hub changes in the plugin GUI. I'd like to force it to just look at one address. Is this possible?
