Hi Wim,
This is not the 1st time. Had it a few months ago around August. Worked fine since then until a couple of days ago. Happened twice, 1st time, 3 out of 8 went offline from HS. The next day a 4th one.
Checked in deConz, all fine, I could control them. So I applied the trick you suggested last time, taking the blind battery out, and do a rescan of devices from the plugin while putting the battery back in. That worked, again, restoring blinds control to HS.
Oddly enough, the 4 remaining blinds didn't experience the issue. May be I'll get it in a day or 2.
This gets me uncomfortable somewhat.
Why would HS and the plugin loose control on some devices while deCONZ doesn't? And what would you suggest to fix this?
Guy
Guy
