Hi, I'm finally getting around to migrating all of my smart home gadgets into Homeseer through JowiHue. I've been able to get my Hue Lights, Senglend Lights, and Aqara sensors all paired successfully through the Conbee2. However, I'm running into an issue in which when adding the devices into HS I have the ability to control brightness & on/off, but no color temperature or RGB control. Is there a setting I'm missing somewhere? Thank you in advance!
[Solved] No Color Control Option
Are all lights without CT or color control, or are this specific lights? As when a bulb supports color, the color features should be created as well.
Which version of HS and plugin are you using? also the deCONZ version might be of influence here?
Wim-- Wim
Are the lights we are seeing here of a specific brand? Are there errors logged when you stop and start the plugin or HS?
If one of these lights should support color, could you go to the properties of the device for this light and check the JowiHue tab? In the bottom of this tab you will find the JSON string as reported by deCONZ, could you copy this text and post this here, so I could have a look at it?
Wim-- Wim
Could be unrelated but HS4.2.0.0 was very buggy when it comes to displaying HS devices. Perhaps an update to 4.2.4.0 may be one course of action?
https://forums.homeseer.com/forum/hs...0-is-available
Originally posted by jon00 View PostCould be unrelated but HS4.2.0.0 was very buggy when it comes to displaying HS devices. Perhaps an update to 4.2.4.0 may be one course of action?
