During my nightly HS4 backups I get these warnings. I just want to confirm they can be skipped and the backups are going to restore my JowiHue is needed. Thanks, Mike
10/27/2021 3:00:04 AM
HomeSeer
Warning
A file cannot be accessed and will be skipped. If this is a plugin owned file the plugin author needs to implement the backup HSEvent: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS4\Data\JowiHue\JowiHue.db-wal' because it is being used by another process.
HomeSeer
Warning
A file cannot be accessed and will be skipped. If this is a plugin owned file the plugin author needs to implement the backup HSEvent: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS4\Data\JowiHue\JowiHue.db-shm' because it is being used by another process.
HomeSeer
Warning
A file cannot be accessed and will be skipped. If this is a plugin owned file the plugin author needs to implement the backup HSEvent: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS4\Data\JowiHue\JowiHue.db' because it is being used by another process.
Date/time=10/27/2021 5:48:01 AM Pacific Daylight Time
Version=HS4 Pro Edition 4.2.5.0 (Windows)
License=Registered
Confguration File=C:\Program Files (x86)\HomeSeer HS4\Data\HomeSeerData.json
In Virtual Machine=No MFG: shuttle inc.
Antivirus=Windows Defender
OS=Microsoft Windows 10 Enterprise 2016 LTSB - Work Station
OS Version=10.0.14393
Uptime=2 Days 22 Hours 13 Minutes 19 Seconds
Lan IP=10.0.1.5 (HomeTrollerS)
Device Count=707
Event Count=71
Processor:=Intel64 Family 6 Model 92 Stepping 9 at 1.86 GHz
Modules/Threads=127 Modules, 75 Threads
Available Threads=1023
System Load=70 Processes, 5% Load
Free/Total Memory=5.99 GBytes / 7.82 GBytes (77% free)
Free/Total Virtual Memory=7.06 GBytes / 9.07 GBytes (78% free)
HomeSeer Memory Used=56 Mbytes
Plugin Memory Used=4 EXE Plug-Ins using 53 Mbytes
Plugins Installed=EasyTrigger 3.0.0.74,Honeywell WiFi Thermostat 1.4.2.2,JowiHue 4.0.5.5,Z-Wave 3.0.7.0
HomeSeer
Warning
HomeSeer
Warning
HomeSeer
Warning
License=Registered
Device Count=707
Event Count=71
