Any Experience with Tuya USB Repeaters
    I was looking for some Zigbee signal repeaters and stumbled across these:
    https://www.aliexpress.com/item/1005003392553626.html
    Does anyone know if these will work with Conbee2/DeConz/JowiHue and if they will are they any good?
    Thanks!
    I do not know the device out of experiance. But a request for support is already on the github: https://github.com/dresden-elektroni...in/issues/5408
    And as this user is posting the request, I suppose the repeater is already functioning in deCONZ. Repeaters are not necessary to show in the plugin as all they do is repeat, Therefore the plugin does not create a device for it as there are no controls. They do their job fine whithout reporting to a REST API. You can check on that when you look at the deCONZ map once they show as device there.
    So I guess you could try to use it in deCONZ?
    They are sure nice and cheap!
    Wim
    -- Wim
      Thanks for the response. I’ll probably order a couple and see what happens.
        Let me know how it goes. Otherwise we might to push on the github issue to get things moving.
        -- Wim
