Thinking about adding a pair of these over a sliding patio door, one blind per door section. Have some questions before I pull the trigger...
I noticed these blinds come with a remote, I'm assuming this is their typical Zigbee remote. In real world usage does one pair the remotes directly to the blinds in deconz or use the remotes to trigger JowiHue/HS4 actions to control the blinds? I know from past experience that pairing remotes directly to things like bulbs ensures almost no latency and will work even if HS4/deconz is offline.
I notice these use a rechargeable battery, how long do they last in between charges? Let's say you're only opening or closing twice a day.
Are there issues with the blinds staying in sync opening and closing?
Any insights from folks using these appreciated.
