It's not a bug but I can't change/add new values for the graphics of this device "TRADFRI wireless dimmer". Because of that i always get this msg on plugin start "Control values of device Sapateira is now in sync with deCONZ"
The button events values for this device are:
Source: https://dresden-elektronik.github.io...tradfri-dimmer
I've already tried in the plugin settings enable "If possibe values of a deCONZ device are not in sync with the HS device, automatically sync the HS device" and on the JowiHue tab of the device "Reset Graphic values for all features belonging to devices".
I still tried to set the values manually but the plugin resets them and goes back to default. The default is a value range 1000 - 6000.
