sometimes errors and plugin restarts
    I noticed in the log these errors (hs4 with hs3 plugin)
    4-11-2021 16:48:42
    Legacy-Plugin
    JowiHue
    Refresh bridge Phoscon-GW set to 45 seconds after establishing direct connection
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Refresh bridge delight set to 45 seconds after establishing direct connection
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Devices added for light On/Off light 8
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Created new colourtemperature device for On/Off light 8
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Created new Hue devices for On/Off light 8
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    socket opened for Phoscon-GW on 192.168.1.77:443
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Devices added for light On/Off light 7
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Created new colourtemperature device for On/Off light 7
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Created new Hue devices for On/Off light 7
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Disabled Colour Temperature control for group Garage
    4-11-2021 16:48:41
    Legacy-Plugin
    JowiHue
    Devices added for light On/Off light 6
    4-11-2021 16:48:40
    Legacy-Plugin/Script
    JowiHue
    4-11-2021 16:48:40
    JowiHue
    0 Animations available for use in this plugin
    4-11-2021 16:48:40
    JowiHue
    0 Local scenes available for use in the JowiHue plugin
    4-11-2021 16:48:40
    JowiHue
    22 Presets available for use in the JowiHue plugin
    4-11-2021 16:48:40
    JowiHue
    -------------------------------------Plugin info ---------------------------------------------
    4-11-2021 16:48:40
    JowiHue
    4 Pressure sensor(s) found on bridge 'Phoscon-GW' with 4 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    4 Humidity sensor(s) found on bridge 'Phoscon-GW' with 4 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    4 Temperature sensor(s) found on bridge 'Phoscon-GW' with 4 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    1 Remote switch(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    Bridge Phoscon-GW is at version 2.5.88 of type deCONZ on a ConBee II
    4-11-2021 16:48:40
    JowiHue
    1 Groups available on bridge 'Phoscon-GW'
    4-11-2021 16:48:40
    JowiHue
    5 lights and/or plugs connected to bridge 'Phoscon-GW'
    4-11-2021 16:48:40
    JowiHue
    -------------------------------------Bridge info ---------------------------------------------
    4-11-2021 16:48:40
    JowiHue
    4-11-2021 16:48:40
    JowiHue
    Bridge Philips hue wk is at version 1948086000 of type BSB002
    4-11-2021 16:48:40
    JowiHue
    3 Groups available on bridge 'Philips hue wk'
    4-11-2021 16:48:40
    JowiHue
    2 lights and/or plugs connected to bridge 'Philips hue wk'
    4-11-2021 16:48:40
    JowiHue
    4-11-2021 16:48:40
    JowiHue
    4-11-2021 16:48:40
    JowiHue
    4 Generic status sensor found on bridge 'Philips hue 2.1'
    4-11-2021 16:48:40
    JowiHue
    1 Remote switch(s) found on bridge 'Philips hue 2.1' with 1 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    1 TAP(s) found on bridge 'Philips hue 2.1' with 1 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    Bridge Philips hue 2.1 is at version 1948086000 of type BSB002
    4-11-2021 16:48:40
    JowiHue
    10 Groups available on bridge 'Philips hue 2.1'
    4-11-2021 16:48:40
    JowiHue
    9 lights and/or plugs connected to bridge 'Philips hue 2.1'
    4-11-2021 16:48:40
    JowiHue
    4-11-2021 16:48:40
    JowiHue
    4-11-2021 16:48:40
    JowiHue
    1 Vibration sensor(s) found on bridge 'delight' with 1 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    2 Fire sensor(s) found on bridge 'delight' with 2 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    2 Pressure sensor(s) found on bridge 'delight' with 2 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    3 Humidity sensor(s) found on bridge 'delight' with 3 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    6 Open/Close sensor(s) found on bridge 'delight' with 6 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    1 Lightlevel sensor(s) found on bridge 'delight' with 1 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    3 Temperature sensor(s) found on bridge 'delight' with 3 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    3 Remote switch(s) found on bridge 'delight' with 3 supporting HS device(s)
    4-11-2021 16:48:40
    JowiHue
    Bridge delight is at version 2.12.6 of type deCONZ on a ConBee II
    4-11-2021 16:48:40
    JowiHue
    1 Groups available on bridge 'delight'
    4-11-2021 16:48:40
    JowiHue
    3 lights and/or plugs connected to bridge 'delight'
    4-11-2021 16:48:40
    JowiHue
    4-11-2021 16:48:40
    JowiHue
    4-11-2021 16:48:40
    Legacy-Plugin
    JowiHue
    socket opened for delight on 192.168.1.140:8088
    4-11-2021 16:48:37
    Legacy-Plugin
    JowiHue
    Mismatching uniqueid for light On/Off light 9 Correcting
    4-11-2021 16:48:37
    Legacy-Plugin
    JowiHue
    Mismatching uniqueid for light On/Off light 8 Correcting
    4-11-2021 16:48:37
    Legacy-Plugin
    JowiHue
    Mismatching uniqueid for light On/Off light 7 Correcting
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    * Connected to bridge Phoscon-GW at 192.168.1.77:80
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    * Connected to bridge Philips hue 2.1 at 192.168.1.89:80
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    * Connected to bridge Philips hue at 192.168.1.13:80
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    * Connected to bridge delight at 192.168.1.140:8080
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    This error was caused by a device called Garage (Bri). If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    Error: (FindBridgesSelf):e objectverwijzing is niet op een exemplaar van een object ingesteld.
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    This error was caused by a device called All Lights woonkamer (bri). If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    This error was caused by a device called lamp grote kast (bri). If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    This error was caused by a device called lamp kleine tafel (bri). If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    This error was caused by a device called staande lamp (bri). If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    This error was caused by a device called lamp grote tafel (bri). If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    This error was caused by a device called Bridge update. If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    This error was caused by a device called All Lights Philips hue (bri). If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:35
    Legacy-Plugin
    JowiHue
    4-11-2021 16:48:34
    Legacy-Plugin
    JowiHue
    This error was caused by a device called Hue bloom 1 (Bri). If this device is not a bridge, please remove it from the devices and let it recreate?
    4-11-2021 16:48:34
    Legacy-Plugin
    JowiHue
    4-11-2021 16:48:29
    HomeSeer
    Starting Plug-In
    Plugin JowiHue started successfully in 216 milliseconds
    4-11-2021 16:48:29
    Legacy-Plugin
    JowiHue
    InitIO:Plugin basic initialisation done
    4-11-2021 16:48:29
    Legacy-Plugin
    JowiHue
    Starting plugin JowiHue 2.1.1.11 on Windows
    4-11-2021 16:48:29
    HomeSeer
    Starting Plug-In
    Initializing plugin JowiHue ...
    4-11-2021 16:48:28
    HomeSeer
    Starting Plug-In
    JowiHue loaded in 15101 milliseconds
    4-11-2021 16:48:14
    HomeSeer
    Info
    Plugin JowiHue has connected. IP:127.0.0.1:57492
    4-11-2021 16:48:13
    HomeSeer
    Warning
    I/O interface JowiHue is down, executable is not running, restarting ...
    4-11-2021 16:47:58
    HomeSeer
    Info
    Plugin JowiHue with ID: and Instance: has disconnected
    4-11-2021 16:47:57
    Legacy-Plugin
    JowiHue
    Restarting plugin due to error datatables
    4-11-2021 16:47:45
    Legacy-Plugin
    JowiHue
    Error: (UpdateGroups):e objectverwijzing is niet op een exemplaar van een object ingesteld.
    4-11-2021 16:47:33
    Legacy-Plugin
    JowiHue
    Error: (UpdateGroups)::In de kolom Ref zijn geen nulls toegestaan.
    4-11-2021 16:47:21
    Legacy-Plugin
    JowiHue
    4-11-2021 16:47:00
    Legacy-Plugin
    JowiHue
    Error: (UpdateGroups)::Voor de kolom BridgeSerial, ID geldt de beperking dat deze uniek moet zijn. De waarde ECB5FAFFFE2A3B18, 4 is al aanwezig.
    4-11-2021 16:46:30
    Legacy-Plugin
    JowiHue
    4-11-2021 16:46:24
    Legacy-Plugin
    JowiHue
    Any idea what is causing this?
    Did you just upgrade to HS4? Or is this after a restart? As I see it creating devices, which might not be a expected result for you?
    I had a similar situation when I was still using the HS3 plugin on HS4. for me I discovered then that the devoces.json file of HS4 was fault. Recovering this file from a backup and a new restart solved the issue for me? Could it be that this is happening here too now?
    Wim
    -- Wim
      No, i upgrades to hs4 quite some time ago, it's not a big problem that te plugin restarts but i was just curious why?
        I worry about these lines (unless you added new devices):
        Legacy-Plugin
        JowiHue
        4-11-2021 16:48:41
        Legacy-Plugin
        JowiHue
        4-11-2021 16:48:41
        Legacy-Plugin
        JowiHue
        4-11-2021 16:48:41
        Legacy-Plugin
        JowiHue
        4-11-2021 16:48:41
        Legacy-Plugin
        JowiHue
        4-11-2021 16:48:35
        Legacy-Plugin
        JowiHue
        This with the lines reporting about the erranous "birdges" which are lights trigger me to worry here. There could be a bit more to this issue. Those make me think of a damaged json file.
        The plugin restarting is an issue that happens every now and then in the HS3 version, but those occasions should be very rare indeed. This fault is solved in the HS4 version BTW.
        Wim
        -- Wim
          No, i did not add any new lights, and i will go to hs4 plugin (when i am bored and have some time to spent )
            Not pushing you to the HS4 plugin at all here, I am not trying to force on this. But I am really worried on the devices mentioned? I do think something is wrong?
            If you do a new restart and new devices are created again, could you try to remove the devices, like the red lines were mentioning and restart the plugin to let it recreate those devices that have been removed? If this does not resolve the issues let me know?
            -- Wim
              after the restart:
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
              5-11-2021 15:39:59
              Legacy-Plugin
              JowiHue
                stupid question:
                what does these groups do?
                -11-2021 16:09:31
                HomeSeer
                Warning
                Device (4421) JowiHue JowiHue Custom group for $roomBR references a parent, but the parent does not exist
                5-11-2021 16:09:31
                HomeSeer
                Warning
                Issue checking child device (4421) JowiHue JowiHue Custom group for $roomBR
                5-11-2021 16:09:31
                HomeSeer
                Warning
                Device (4420) JowiHue JowiHue Custom group for $roomTR references a parent, but the parent does not exist
                5-11-2021 16:09:31
                HomeSeer
                Warning
                Issue checking child device (4420) JowiHue JowiHue Custom group for $roomTR
                5-11-2021 16:09:31
                HomeSeer
                Warning
                Device (4419) JowiHue JowiHue Custom group for $roomBL references a parent, but the parent does not exist
                5-11-2021 16:09:31
                HomeSeer
                Warning
                Issue checking child device (4419) JowiHue JowiHue Custom group for $roomBL
                5-11-2021 16:09:31
                HomeSeer
                Warning
                Device (4418) JowiHue JowiHue Custom group for $roomTL references a parent, but the parent does not exist
                5-11-2021 16:09:31
                HomeSeer
                Warning
                Issue checking child device (4418) JowiHue JowiHue Custom group for $roomTL
                  5-11-2021 17:35:19
                  Legacy-Plugin
                  JowiHue
                  Warning: Bridge Philips hue wk is slow in responding. JowiHue temporary changed Refreshrate to 72 seconds for this bridge
                  5-11-2021 17:35:19
                  Legacy-Plugin
                  JowiHue
                  Warning: Bridge Philips hue 2.1 is slow in responding. JowiHue temporary changed Refreshrate to 72 seconds for this bridge
                  perhaps moving to the hs4 plugin is not a bad idea
                    Originally posted by akatar View Post
                    stupid question:
                    -11-2021 16:09:31
                    HomeSeer
                    Warning
                    I guess these groups are created by another app, maybe the Hue labs (which uses a lot of $xxxxx grouping) or Philips Hue app? The plugin finds these groups and creates devices for it. It is not something from the plugin itself. But also here the errors are pointing to missing devices.....
                    Again, I think you have a damaged devices.json file. Do you have a backup of the json files from the date before these errors started?
                    I would not advise to let the HS4 plugin do the conversion in this state. Did you try to remove the mentioned devices?
                    Wim
                    -- Wim
                      I removed a couple, not all of them yet. i have to recreate all events i guess?
                      i don't use other apps
                      When i have some time tp spent, i will delete them all and go to the hs4 plugin
                        If you need to update the events depends on how you have build the events. If you have been using the JowiHue action, then there is no change needed as those are device independent. If you have used device actions for setting the lights, you need to update the existing events. The easiest way to do this is using the folowing steps:
                        1. Decide which device you are going to remove (don't do it just yet)
                        2. Open a browser tab with the HS devices page open.
                        3. In the top right there is a search box. Search here for the devicename. You will see list of events where the device is used. Do not close this page!
                        4. Open a second browser window and delete the device and its child devices
                        5. Let the plugin restart and create the new device
                        6. Go back to the search window and right click on an event link, open in new tab.
                        7. Now you can adjust the event with addressing the new device
                        8. repeat step 6 and 7 for each event
                        Do the above steps per device and you will discover this is a method that works even quite fast when you do it.
                        Wim
                        -- Wim
                          Thank you for the advice Wim
