Hi, I am looking for some guidance on the proper way to start things up and was hoping there's someone who's figured this out.
System: Windows 10
HS4, JowiHue plugin, and DeConz for a Conbee II gateway
I have crashes sometimes that cause the computer to reboot. I have disabled windows updates so it's not that.
I was finally able to find an article https://docs.homeseer.com/pages/view...ageId=17466614 that showed how to create a windows task and start HS4.exe on system logon. This is the first time I'm able to get HS4 to start on reboot, and it works.
However, here's my dilemma:
Original setup:
1. I had the DeConz program in my "startup" folder so it would start after a reboot.
2. When HS4 finally started from the "task" I created, it complained that the http (port 80) port was busy and it wouldn't start. I assume the DeConz started up something on port 80.
3. This scenario didn't work because hs4 didn't start up.
New setup:
1. I created another Windows task for DeConz to start up one minute after logon so HS4 would have a chance to grab port 80. I removed the "startup folder" shortcut for this.
2. This all works and things start up properly, but now the JowiHue plugin seems to not be connected to the DeConz gateway (no devices work).
So my questions are:
1. Can I change the default http port for DeConz so it doesn't occupy port 80? Maybe then it can start first and everything will just work because the gateway will be "up" when HS4 starts.
2. How do I get JowiHue to "auto reconnect" to a gateway if the gateway was offline temporarily?
Thanks for any tips here!
Dennis
System: Windows 10
Original setup:
New setup:
Dennis
