JowiHue HUE dimmer switch 1 and creating events
    When use a HUE dimmer switch 1 "button press" as trigger for an event, it's hard to see witch button it is.
    In HS3 the buttons are named, On, Off, Dim down and Dim up.
    In HS4 (with HS4 plug-in) the names are button 1, button 2 etc.
    Also holding and release are gone.
    That's back in time....
    Can it added?
    Are you using the Philips Hue bridge or deCONZ? If you are using deCONZ, which version are you using? Did you convert from HS3? As in that case, the buttons have not changed from HS3.
    If new created, the dimmer switch should get the correct statuses. Can you post an image of both the status/graphics page and the JSON on the JowiHue tab?
    Wim
    -- Wim
      I'm ussing an HUE Bridge
      See also an example of the same device in HS3.
        The HS4 plugin is using the definitions as the Phiips Hue bridge is delivering it. It is no longer using "my" definitions for devices like in HS3 - if Philips or deCONZ deliver the button values, the plugin will use those.
        But you can always change the used descriptions (not values!) in the Status/Graphics to your liking. The plugin should not change those unless you choose to reset the values, or if Philips (or deCONZ at the next release of deCONZ) change the used values for any reason.
        Wim
        -- Wim
