When there is a power outage, everything comes back up but somehow when the HS4 PC comes up it doesn't see the raspbee/JowiHue. I've been rebooting the raspbee and restarting HS4 (both manually) then everything is fine.
I "assume" the raspbee is up and running before the PC since it's just a RPi3 and I also have a 90second delay for HS4 through Startup Delay on the PC.
Thee are the only errors I see:
11/13/2021 14:57:14 JowiHue Warning Warning: Bridge deCONZ-GW-RPi3 Not reachable. (this every 5 minutes)
11/13/2021 14:52:32 JowiHue Info Error:A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond (this one time at startup process)
I saw something mentioned about this but can't find the post, so I have to ask again. Help please.
