Hi,
I just installed a number of RGBW bulbs thinking I would be able to set and modify the RGB or color temperature value easily from the HS4 device page but the color defaults to #303030 rather than the actual RGB value. Hue and ERIA RGB bulbs behave the same way. Is this normal behavior or is there a setting somewhere that needs to be changed? I am running HS4 Pro 4.2.6 with Jowihue 4.0.6.0
