Jowihue was working without known issues. I just updated the plugin and now it shows up only in the list of “Installed” plug-ins, but disappeared from the Plug-ins drop-down menu.
I am running HS4 Pro Edition 4.1.9.0 (Windows). My HS controller was upgraded from HS3 a long time ago.
The log file shows errors, provided below. The install appears to detect that I am running below HS4 v4.1.17.
I’m unsure how to install the previous version found in the ..\Updates4 folder. Can someone tell me how?
Also, any recommendations to install latest released version?
12/9/2021 2:35:30 PM
HomeSeer
Plug-In
Finished initializing plug-in JowiHue
HomeSeer
Starting Plug-In
JowiHue loaded in 1096 milliseconds
HomeSeer
Starting Plug-In
Plugin JowiHue started successfully in 260 milliseconds
JowiHue
Error
Error: (Initialize):Warning!! The plugin will now stop functioning
JowiHue
Error
Error: (Initialize):Warning!! You can check the \Updates4 directory of the HS installation directory for a previous version?
JowiHue
Error
Error: (Initialize):Warning!! Please install a previous version (<= 4.0.4.5) of the Jowihue plugin
JowiHue
Error
Error: (Initialize):Warning!! This version of the plugin (4.0.6.0) needs HS4 version 4.1.17 or higher!
JowiHue
Info
settings loaded
JowiHue
Info
Starting plugin JowiHue 4.0.6.0 on Windows
JowiHue
Info
Logfile is set to C:\Program Files (x86)\HomeSeer HS3/Logs/JowiHue.log
HomeSeer
Starting Plug-In
Initializing plugin JowiHue ...
HomeSeer
Info
Plugin JowiHue with instance JowiHue has connected. IP:127.0.0.1:57461
12/9/2021 2:34:26 PM
HomeSeer Updater
Info
Plugin JowiHue installed successfully.
12/9/2021 2:34:23 PM
HomeSeer Updater
Info
Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_JowiHue.exe.config
HomeSeer Updater
Info
HomeSeer Updater
Info
Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\InnerCore.Api.HueSync.dll
HomeSeer Updater
Info
Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\SuperSocket.ClientEngine.dll
HomeSeer Updater
Info
Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\WebSocket4Net.dll
HomeSeer Updater
Info
Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\Newtonsoft.Json.dll
HomeSeer Updater
Info
Making dir: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\
HomeSeer Updater
Info
Extraction Complete.
HomeSeer Updater
Info
Extracting files from zip file: JowiHue_html.zip
HomeSeer Updater
Info
12/9/2021 2:34:22 PM
HomeSeer Updater
Info
Extracting files from zip file: JowiHue_images.zip
HomeSeer Updater
Warning
File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Data\JowiHue\JowiHue.db
HomeSeer Updater
Info
Copying file: C:\Program Files (x86)\HomeSeer HS3\Config\JowiHueImports.xml
12/9/2021 2:34:21 PM
HomeSeer Updater
Info
Plugin install for JowiHue starting...
HomeSeer
Plug-In
HomeSeer
Starting Plug-In
HomeSeer
Starting Plug-In
JowiHue
Error
JowiHue
Error
JowiHue
Error
JowiHue
Error
JowiHue
Info
settings loaded
JowiHue
Info
JowiHue
Info
HomeSeer
Starting Plug-In
HomeSeer
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Info
HomeSeer Updater
Warning
HomeSeer Updater
Info
HomeSeer Updater
Info
